BanditSRT8 Posted September 20, 2008 Report Share Posted September 20, 2008 So you may remember I have posted about hearing my supercharger belt squealing under hard shifts. On those threads many others have said they hear it as well. Well, I found out yesterday that it is absolutely NOT the supercharger belt squealing! It is our alternator belt. I know, I know... I argued it as well, but here's what I found out at the SVT-specific speed shop I went to..... IF the s/c belt was squealing (and of course they have the ability) they would not do it when you shift, but under load when the s/c is spinning up. For example, if you were riding 3rd gear up high then slammed on the gas (no gear changing) then when the load was heavy on the motor and on the s/c, you would then hear the squeal. In my case, and in some other's who have posted, the squeal happens when you dump the clutch after engaging the gear. A quick little chirp that comes from under the hood. As it was explained to me, then as I witnessed, the alternator belt is running fast then when you push the clutch in, rotation slows down on the alternator and when you dump the clutch after entering the next gear, the alternator is barely moving... then the belt tries to go fast with the alternator hub barely spinning... there's your squeal. The alternator spinning slowly and the belt sliding across it that's moving faster. As it was explained to me, this causes no damage or excessive wear, but if it ever did, the worst you'd have to worry about is replacing a worn alternator belt. Link to comment Share on other sites More sharing options...
XLR8 Posted September 21, 2008 Report Share Posted September 21, 2008 Thanks, Good info to know. Link to comment Share on other sites More sharing options...
Light66 Posted September 22, 2008 Report Share Posted September 22, 2008 So you may remember I have posted about hearing my supercharger belt squealing under hard shifts. On those threads many others have said they hear it as well. Well, I found out yesterday that it is absolutely NOT the supercharger belt squealing! It is our alternator belt. I know, I know... I argued it as well, but here's what I found out at the SVT-specific speed shop I went to..... IF the s/c belt was squealing (and of course they have the ability) they would not do it when you shift, but under load when the s/c is spinning up. For example, if you were riding 3rd gear up high then slammed on the gas (no gear changing) then when the load was heavy on the motor and on the s/c, you would then hear the squeal. In my case, and in some other's who have posted, the squeal happens when you dump the clutch after engaging the gear. A quick little chirp that comes from under the hood. As it was explained to me, then as I witnessed, the alternator belt is running fast then when you push the clutch in, rotation slows down on the alternator and when you dump the clutch after entering the next gear, the alternator is barely moving... then the belt tries to go fast with the alternator hub barely spinning... there's your squeal. The alternator spinning slowly and the belt sliding across it that's moving faster. As it was explained to me, this causes no damage or excessive wear, but if it ever did, the worst you'd have to worry about is replacing a worn alternator belt. Thank you. Mine has had the squeal from the very beginning. Link to comment Share on other sites More sharing options...
FiaCobra Posted September 23, 2008 Report Share Posted September 23, 2008 With the SLP's installed, I can't hear s**t.............problem solved !!! Link to comment Share on other sites More sharing options...
07SHELBY GT Posted September 23, 2008 Report Share Posted September 23, 2008 Mine just started that noise.Sounds exactly like when you shut off a Cummins diesel Dodge,Quick chirp.I guess we shift so damn fast we are outrunning the alternator.Look out Ronnie Sox,Mr 4 speed here I come! Link to comment Share on other sites More sharing options...
