How many miles should we get out of our motors?
formervettowner
If it is like the past Mustangs the body will fall aparrt around the motor. This is a different car now, the LS chassis and some quality control improvements may surprise us. Were in uncharted territory, time will tell. My guess is after the warranty ends and a couple replacements of the clutch and transmissions on our tab, many will see loyalty fade and move on to another toy.
  • 2 weeks later...
The block, pistons, rods, crank bearing/journals, oil control system, and most of the 5.4L internal are tank strong. The heads, cam chain and it's tensioning system might get you near 100K. The Blower is another story and that should be my main concern. Regardless of usage, blowers inherently require attention because they just aren't designed for longevity. And before I get hammered with replies, remember this...your're looking at the 5th Generation redesign of this particular blower. Why so many? And also, this isn't a new application for Ford. Early Cobra's (prior to the S197 design) were shelling out like cheap concert tickets. Ford dealers will even tell you that, like they did me. Granted, today's car and especially this one has had alot of attention in it's $19,500 engine design, I'd still watch out for two things; heat related damage, simply because things are so tightly packed underneath that hood, and the heat generating blower. Check out the Eaton Blower website. Haven't heard anything negative on the Whipple or Kenne Bell blowers yet but they're also cooled by an enormous heater exchanger.
Airborne
