andrewnagle1964 Posted September 7, 2008 Report Share Posted September 7, 2008 I am interested in changing my "Master Cylinder" to an aluminum one. Does anyone know the bore size needed to match the original? And does anyone have any recommendations. I am looking at Wilwood's Aluminum Tandem Chamber Master Cylinder Wilwood Thanks and take care, Andrew Nagle Link to comment Share on other sites More sharing options...
clark17357 Posted September 7, 2008 Report Share Posted September 7, 2008 What are the perceived advantages to going to an aluminum model? Thanks. Jim Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 7, 2008 Author Report Share Posted September 7, 2008 What are the perceived advantages to going to an aluminum model? Thanks.Jim Absolutely none other than the plastic one looks like.... :koolaid: and it doesn't go well with the Moroso aluminum tanks in my engine bay. Definitely a valid question though Thanks, Andrew Link to comment Share on other sites More sharing options...
Son of GT Posted September 8, 2008 Report Share Posted September 8, 2008 Not just appearance, the Wilwood will deliver higher pressures to the slave cylinder and brake calipers too. Link to comment Share on other sites More sharing options...
Reino Posted September 8, 2008 Report Share Posted September 8, 2008 Absolutely none other than the plastic one looks like.... :koolaid: and it doesn't go well with the Moroso aluminum tanks in my engine bay.[/size] Looking good. May want to try a fuse box, or atleast cover while your at it. Looking good though. Link to comment Share on other sites More sharing options...
CH53Driver Posted September 8, 2008 Report Share Posted September 8, 2008 I think it would make for a great addition to your already impressive engine bay. Any idea on how much it costs? Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 8, 2008 Author Report Share Posted September 8, 2008 I think it would make for a great addition to your already impressive engine bay. Any idea on how much it costs? Summit Racing is selling the polished version for about $240 Thanks for the compliment. Summit/Wilwood Take Care Andrew Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 8, 2008 Author Report Share Posted September 8, 2008 Looking good. May want to try a fuse box, or atleast cover while your at it. Looking good though. Definitely a good ideas just don't know if I want the plain one or the one with the Shelby logo. I am also looking at radiator covers from SS Inserts SS inserts Thanks for the compliment Andrew Link to comment Share on other sites More sharing options...
CH53Driver Posted September 9, 2008 Report Share Posted September 9, 2008 Definitely a good ideas just don't know if I want the plain one or the one with the Shelby logo. I am also looking at radiator covers from SS Inserts SS inserts Thanks for the compliment Andrew Whoa, that one radiator cover with the P-51's is way cool. I don't know where in NC you are, but you should come out to the OBX for the get together next month (weekend of the 10th). There is a thread under the SE forum forum for it. Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 9, 2008 Author Report Share Posted September 9, 2008 Whoa, that one radiator cover with the P-51's is way cool. I don't know where in NC you are, but you should come out to the OBX for the get together next month (weekend of the 10th). There is a thread under the SE forum forum for it. We are near Asheville in the Mountains, are you in the Outer Banks ? If so I hope you did not have an issues this past weekend with Hanna. I will be headed to China on the 9th for 3 weeks, but thanks for the invite, Take Care, Andrew Link to comment Share on other sites More sharing options...
CH53Driver Posted September 9, 2008 Report Share Posted September 9, 2008 I'm actually stationed in the Norfolk area right now, but maintain my house down near Wilmington. Enjoy China and if you do get the brake cylinder post pics so we can see how it turned out. Link to comment Share on other sites More sharing options...
WP64 Posted September 12, 2008 Report Share Posted September 12, 2008 Does Wilwood make a MC with a hose barb from the fluid reservoir to supply brake fluid to the hydraulic clutch? If you look at the OE MC you will see the clutch fluid supply line on the rear drivers side of the fluid reservoir. I could be added to the Wilwood MC I'm sure, but just keep in mind that this would need to be done if you switched out to the Wilwood MC. Jay EDIT - You could also add a small seperate reservoir for the clutch fluid. Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted September 12, 2008 Author Report Share Posted September 12, 2008 Does Wilwood make a MC with a hose barb from the fluid reservoir to supply brake fluid to the hydraulic clutch? If you look at the OE MC you will see the clutch fluid supply line on the rear drivers side of the fluid reservoir. I could be added to the Wilwood MC I'm sure, but just keep in mind that this would need to be done if you switched out to the Wilwood MC. Jay EDIT - You could also add a small seperate reservoir for the clutch fluid. Jay Thanks for the advice and heads up. Take Care, Andrew Link to comment Share on other sites More sharing options...
