03snake Posted May 29, 2008 Report Share Posted May 29, 2008 Installed Eibach Pro Street S coil over system, BMR Upper control arm, Lower control arms and Panhard bar, all adjustable. It is a different car all the way around. I ended up lowering about 1 1/2" in front and close to 1 3/4" in the rear. Put it on the scales to balance it with me in the car and then had it aligned. Weight of the car with me it it registered 4011lbs, not sure thats right because I weigh about 257lbs..........Will post pics later tonight. Link to comment Share on other sites More sharing options...
bigdrawz24 Posted May 30, 2008 Report Share Posted May 30, 2008 Installed Eibach Pro Street S coil over system, BMR Upper control arm, Lower control arms and Panhard bar, all adjustable. It is a different car all the way around. I ended up lowering about 1 1/2" in front and close to 1 3/4" in the rear.Put it on the scales to balance it with me in the car and then had it aligned. Weight of the car with me it it registered 4011lbs, not sure thats right because I weigh about 257lbs..........Will post pics later tonight. Yes please post pics asap, i cant wait to see this set up. Planning on doing something with mine as well......it sounds like it looks real good!!! Link to comment Share on other sites More sharing options...
