redwingone Posted May 11, 2008 Report Share Posted May 11, 2008 the gt500 has been sitting since last october without being started .Do I need to use the engine preoiler as in the FRPP catalog for a prelubrication or can I just go ahead and spin er up?? 1200 miles, 08, and garaged. Thanks, Ken Link to comment Share on other sites More sharing options...
68fastback Posted May 11, 2008 Report Share Posted May 11, 2008 the gt500 has been sitting since last october without being started .Do I need to use the engine preoiler as in the FRPP catalog for a prelubrication or can I just go ahead and spin er up?? 1200 miles, 08, and garaged. Thanks, Ken I'd change the oil and filter and make sure the battery is fully charged. Then I'd crank the engine without her being able to fire-up (don't know how to do that on thses cars). Once you see oil pressure I think you can then safely fire it up. Dan Link to comment Share on other sites More sharing options...
JonW Posted May 11, 2008 Report Share Posted May 11, 2008 I'd change the oil and filter and make sure the battery is fully charged. Then I'd crank the engine without her being able to fire-up (don't know how to do that on thses cars). Pull the fuel pump relay? Link to comment Share on other sites More sharing options...
redwingone Posted May 11, 2008 Author Report Share Posted May 11, 2008 ok. thanks guys,makes sense. ken Link to comment Share on other sites More sharing options...
1FAFP90 Posted May 15, 2008 Report Share Posted May 15, 2008 IIRC, on the Ford GT, if you depress the accelerator to the floor while starting the car, it will NOT let the engine turn over. It is part of the oil change procedure. Maybe someone can confirm whether or not the same logic was put in the GT500's computer. Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted May 15, 2008 Report Share Posted May 15, 2008 IIRC, on the Ford GT, if you depress the accelerator to the floor while starting the car, it will NOT let the engine turn over. It is part of the oil change procedure. Maybe someone can confirm whether or not the same logic was put in the GT500's computer. well....... just go out & do it on your car & then come back & tell us if it works or not Link to comment Share on other sites More sharing options...
