HARALD KELLEY Posted May 4, 2008 Report Share Posted May 4, 2008 This may have been discussed on the old forum but I do not recall the outcome. I need to replace the hood pins and was going to purchase the new improved stainless set from SPP. I was also considering the black billit set. Will they (billet set) work & do the holes line up? I do not want to change if I got to redrill or other modifications. Thanks Link to comment Share on other sites More sharing options...
bullittmansparts Posted May 4, 2008 Report Share Posted May 4, 2008 Harold , they will work......But you will have to alter/bend the upright bracket so the cross pin will sit in the new billet frame. I have a set but went back to the flat SS plate that are like the originals to avoid that. Link to comment Share on other sites More sharing options...
ShelbyKindaGuy Posted May 4, 2008 Report Share Posted May 4, 2008 Harold , they will work......But you will have to alter/bend the upright bracket so the cross pin will sit in the new billet frame. I have a set but went back to the flat SS plate that are like the originals to avoid that. Pictures of the new hood pins show a grove that the cross-pin should be able to just slide into and track to, so why does the bend to the cross-pin have to be done. Is teh groove not deep enough or what? Link to comment Share on other sites More sharing options...
bullittmansparts Posted May 5, 2008 Report Share Posted May 5, 2008 Pictures of the new hood pins show a grove that the cross-pin should be able to just slide into and track to, so why does the bend to the cross-pin have to be done. Is teh groove not deep enough or what? The billet base is thicker and when placed on the GT-H hood changes the angle....The slot in the billet is grooved and the pin will not fit unless you alter it some. Don't get me wrong it is a quality piece, but IMO made for a flat hood, i.e. stock. Link to comment Share on other sites More sharing options...
