IASHELBYGT Posted March 20, 2008 Report Share Posted March 20, 2008 After seeing Stumps post of mods done at Quantum Performance I decided to spring for the camber bolts and a realignment at my local tire shop. The have a laser alignment machine and I had it aligned with in Ford specs. They gave me a print out of the before and after, which I'll try to attach. The camber was off some but not as much as I thought. Anyway, good peace of mind for me and my tires. Dave Link to comment Share on other sites More sharing options...
SGT#3670 Posted March 20, 2008 Report Share Posted March 20, 2008 What did something like that cost if you do not mind? Link to comment Share on other sites More sharing options...
dave c Posted March 20, 2008 Report Share Posted March 20, 2008 After seeing Stumps post of mods done at Quantum Performance I decided to spring for the camber bolts and a realignment at my local tire shop. The have a laser alignment machine and I had it aligned with in Ford specs. They gave me a print out of the before and after, which I'll try to attach. The camber was off some but not as much as I thought. Anyway, good peace of mind for me and my tires. Dave LOL Once I got the magnifying glass out, it appears it was pretty close. Did you notice any handling difference? Were you tires wearing evenly? What I find really strange is some cars are really close to the Ford specs< while others are way off. I guess at the price of tires and how long they typically last, which isn't very long, I guess piece of mind has it's price. Link to comment Share on other sites More sharing options...
mffarrell Posted March 20, 2008 Report Share Posted March 20, 2008 After seeing Stumps post of mods done at Quantum Performance I decided to spring for the camber bolts and a realignment at my local tire shop. The have a laser alignment machine and I had it aligned with in Ford specs. They gave me a print out of the before and after, which I'll try to attach. The camber was off some but not as much as I thought. Anyway, good peace of mind for me and my tires. Dave Will the 1st year warranty cover alignment problems? Link to comment Share on other sites More sharing options...
mywickedshelby Posted March 20, 2008 Report Share Posted March 20, 2008 What did something like that cost if you do not mind? Some have gotten this done under warranty....others were denied thru warranty, but the Eibach lower camber bolts are $30 and I dont know what the alignment shop cost would be.......yet! Link to comment Share on other sites More sharing options...
RogerS Posted March 20, 2008 Report Share Posted March 20, 2008 As Michael stated the bolts are $30 dollars. So that and a great alignment are much cheaper than tires. Sign me up for cheap pice of mind. Link to comment Share on other sites More sharing options...
mywickedshelby Posted March 20, 2008 Report Share Posted March 20, 2008 I'm learnin.....slowly, but I am learnin! Link to comment Share on other sites More sharing options...
IASHELBYGT Posted March 20, 2008 Author Report Share Posted March 20, 2008 What did something like that cost if you do not mind? The camber bolts were $33 dollars from Auto Parts warehouse, but I've seen them a little cheaper on e-bay, the install and laser alignment were another $89.00...so $122 total. As Roger said much cheaper than a new set of tires. Sorry if the attachment was hard to read, if you click on the sheet itself from my post it opens up in a larger format. I tried to get mine covered by warranty through my dealer but Ford Racing nor SAI would cover it. I was glad my settings were close, but now I know. I think the car handles a little better but Iowa roads are still pot hole filled so I didn't get on it too hard. Dave Link to comment Share on other sites More sharing options...
moabman Posted March 20, 2008 Report Share Posted March 20, 2008 One thing you might want to consider is that the strut mount on the GTs including the Shelby GT has shown a tendency to fail over time and introduce a clunk. There are several caster camber plate replacement strut mounts coming on the market. They will be more expensive than the camber bolts but will allow a wider adjustment camber zone and also allow caster. If you plan on tracking your car, this might be the cheapest solution in the long run. Link to comment Share on other sites More sharing options...
SGT0649 Posted March 20, 2008 Report Share Posted March 20, 2008 The dealer should do this under warranty. Mine was done two weeks ago at a dealership (not the one where I bought it) under warranty. Although not out of spec by much it still drives better. Luckily no tire wear... Unless you want to spend the money check with the dealership first. Link to comment Share on other sites More sharing options...
IASHELBYGT Posted March 20, 2008 Author Report Share Posted March 20, 2008 The dealer should do this under warranty. Mine was done two weeks ago at a dealership (not the one where I bought it) under warranty. Although not out of spec by much it still drives better. Luckily no tire wear... Unless you want to spend the money check with the dealership first. Yep, that's what I did and like I said before both FR and SAI said no when called by the dealer. Basically mine was too close to factory specs and the way the car was lowered that we should expect that it was set up with more negative camber. Covered or not I'm glad I made the change. Link to comment Share on other sites More sharing options...
