Shelby N.Y. Posted February 18, 2008 Report Share Posted February 18, 2008 I installed the shelby map light trim piece, and it looked great. I noticed a few days later that the both ends of the piece had come "unglued"(it is attached with double stick tape) and it didn't sit flush anymore. I was wondering if anyone knows of a quality glue that won't run and will keep the trim piece in place. ok let the flogging begin also it has been very cold here in n.y. and allthough the car is garaged it is not heated, so I am pretty sure thats why the tape didn't hold. Link to comment Share on other sites More sharing options...
ShowCar Posted February 18, 2008 Report Share Posted February 18, 2008 I have read this is common problem.You may have to bend the piece to form fit it properly. Link to comment Share on other sites More sharing options...
gofastguy Posted February 18, 2008 Report Share Posted February 18, 2008 I am hoping to hear of a good solution that doesn't involve Crazy Glue since I really want this piece. Do any of you have it installed with the anti-theft? I am wondering if it still looks nice with the holes in the sides for the AAT...the pics I have seen are for the regular trim piece. Link to comment Share on other sites More sharing options...
07shelbygt109 Posted February 18, 2008 Report Share Posted February 18, 2008 It is really a non issue. I would suggest removing the piece and cleaning all the old tape off. Test fit it without the tape and form it to fit like it should, you should only have to bend the ends just a little bit. Get some new tape from a parts house, most of them will stock the thin double sided tape. If it is cold where you are, use a hairdryer to heat the plastic and the cover. Reinstall the piece with the new tape and you should be good to go. Also it would probably be a good idea to have the interior of the car as warm as possible and let the tape cure for a while and then let the temperature drop slowly. As for installing with the anti-theft, I have seen a discussion on that in one of the old site threads and I think someone did it but I don't remember who. Link to comment Share on other sites More sharing options...
mffarrell Posted February 18, 2008 Report Share Posted February 18, 2008 I am hoping to hear of a good solution that doesn't involve Crazy Glue since I really want this piece. Do any of you have it installed with the anti-theft? I am wondering if it still looks nice with the holes in the sides for the AAT...the pics I have seen are for the regular trim piece. Silicone sealer...worked like a charm for me! Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted February 18, 2008 Report Share Posted February 18, 2008 Hopefully, this will help... As a mechanical engineer, I have spec'd adhesive foam tape on various parts. Also, I bought and installed the same map light trim kit from SAI. There are 2 rules to successfully using adhesive foam tape: 1) Clean the surfaces with alcohol or acetone, etc. 2) Hold in place for at least 12 hours. Overnight works. I know it says it only takes 5 minutes or so, but trust me; it takes much longer for a good bond. I installed the piece and used a rubber band around the housing to hold it in place overnight. Now, it stays in place like is was meant to. Link to comment Share on other sites More sharing options...
mrhugger Posted February 18, 2008 Report Share Posted February 18, 2008 Mine worked so great after several frustrating days it hit the out box. Steve Link to comment Share on other sites More sharing options...
shel-b001 Posted February 18, 2008 Report Share Posted February 18, 2008 Yep had the same problem & I followed the instructions to a T . ,ended up using a dab of silicone. Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted February 18, 2008 Report Share Posted February 18, 2008 I had the same issue. I carefully peeled the trim off, reshaped it, (slight pressure to bend - NOT CREASE - it into a more rounded contour), then replaced it. No problems since. SEF AKA: Link to comment Share on other sites More sharing options...
blueshawk Posted February 18, 2008 Report Share Posted February 18, 2008 I installed the shelby map light trim piece, and it looked great. I noticed a few days later that the both ends of the piece had come "unglued"(it is attached with double stick tape) and it didn't sit flush anymore. I was wondering if anyone knows of a quality glue that won't run and will keep the trim piece in place. ok let the flogging begin also it has been very cold here in n.y. and allthough the car is garaged it is not heated, so I am pretty sure thats why the tape didn't hold. I had the same problem with the ends lifting up and use this on the ends of the shelby emblem. http://multimedia.3m.com/mws/mediawebserve...s6EVs6E666666-- Apply it sparingly using a Q-tip on just the ends and hold in place with masking tape over night. Just be careful to lift the ends enough to get some glue under it without bending the trim piece. It's been solid for about 10 months now. Link to comment Share on other sites More sharing options...
willyumm930 Posted February 18, 2008 Report Share Posted February 18, 2008 My wife pulled mine off and added better 3m tape to it and it is 100 times better. She did the same with the sill plate accent strips. I am sure these products were tested before they were sold, right? Sorry, just a little frustrated. Link to comment Share on other sites More sharing options...
Reino Posted February 20, 2008 Report Share Posted February 20, 2008 Ive had mine sitting in the living room for atlease a month and a half now. Received it and wasnt impressed with the jagged edges and how thin the piece is. Im almost afraid of trying to put it on. Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted February 20, 2008 Report Share Posted February 20, 2008 My wife pulled mine off and added better 3m tape to it and it is 100 times better. She did the same with the sill plate accent strips. I am sure these products were tested before they were sold, right? Sorry, just a little frustrated. Yes. Remember, with any adhesive tape product, apply pressure for at least 12 hours or more. Then they will work as advertised. Rubber bands are great for the map light cover. Link to comment Share on other sites More sharing options...
Shelby N.Y. Posted February 20, 2008 Author Report Share Posted February 20, 2008 Thanks for all the help guys, I am going to try using the thicker tape and holding it in place with the rubber band. I'm glad I wasn't the only one with this problem. Link to comment Share on other sites More sharing options...
SMGT Posted February 21, 2008 Report Share Posted February 21, 2008 First I bent it to make the best fit and then used super glue to make it stick as the tape did not work. I also held it in place with blue painter's masking tape as it does not leave any glue residue. I also used the glue to attached the button covers and held them with the same tape for 24hours. All has been fine for 7 months. Link to comment Share on other sites More sharing options...
pagerart Posted February 22, 2008 Report Share Posted February 22, 2008 I used thicker mounting tape near the ends. Just a very small piece on each side and it worked great. Hasn't moved at all, even after sitting in the heat. Link to comment Share on other sites More sharing options...
willyumm930 Posted February 24, 2008 Report Share Posted February 24, 2008 I also used the glue to attached the button covers and held them with the same tape for 24hours. All has been fine for 7 months. I didn't have any issue with the button covers. Link to comment Share on other sites More sharing options...
Grabber Posted January 15, 2009 Report Share Posted January 15, 2009 I'm glad to of read this thread. I'm not wanting to use superglue, so I will use the rubberbands and I have some super good extra strength double sticky tape that I will put on the ends. Thanks for all the tips. I'm going to install mine this week end. A hair dryer and heating the car up are great tips. I did not think of that. Link to comment Share on other sites More sharing options...
stormeaston Posted January 15, 2009 Report Share Posted January 15, 2009 I had the same problem with mine, I bent it to form better to the map light and it's been perfect ever since. Link to comment Share on other sites More sharing options...
backafter20 Posted January 15, 2009 Report Share Posted January 15, 2009 I really wanted this mod, and thought it looked great, until I bought it. The quality was crap, and it never fit right out of the package. I massaged and played with it for hours, stuck it on, watched it fall off. Stuck it on again, pulled it off, massaged and bent it, and redid everything several times. I eventually pulled it off and took it back for a refund. I love the idea, but that piece of aluminum foil they make it out of was just cheesy. I'd love to buy it again, but only if they use thicker metal and get a better stamping. Very ticked about the whole thing... Link to comment Share on other sites More sharing options...
WildAzCat Posted January 16, 2009 Report Share Posted January 16, 2009 I actually thought the quality of mine was okay. I also had the same problem with adhesion. After a few days of it coming up at the sides I decided to remove it and apply a new strip of 3M. That did the trick. I think the flaw is mainly due to the low quality tape used by the manufacturer. Link to comment Share on other sites More sharing options...
