mrshelby2 Posted February 13, 2008 Report Share Posted February 13, 2008 I know how to view new posts, is there also a way to mark all threads read? Thanks Mr S. Link to comment Share on other sites More sharing options...
Alloy Dave Posted February 13, 2008 Report Share Posted February 13, 2008 I know how to view new posts, is there also a way to mark all threads read? Thanks Mr S. Yes. How you do it depends on how you are viewing posts. 1) If you use the "view new posts" option, then there is a link at the top of the section on that page that says "Mark all threads as read and return to index" 2) If you are in a particular forum section, such as "off topic", then you will see a box in the upper right of the section (NOT the upper right of the page) that says "Forum Options", and under that you can find the same link as mentioned in #1 above. Dave Link to comment Share on other sites More sharing options...
rpretzel Posted February 13, 2008 Report Share Posted February 13, 2008 Yes. How you do it depends on how you are viewing posts. 1) If you use the "view new posts" option, then there is a link at the top of the section on that page that says "Mark all threads as read and return to index" 2) If you are in a particular forum section, such as "off topic", then you will see a box in the upper right of the section (NOT the upper right of the page) that says "Forum Options", and under that you can find the same link as mentioned in #1 above. Dave Option #2 does not work at this time. Sharon said they are working on it. Also you should be able to click the image to mark all posts in that section as read, but that function doesn't work at this time either. Link to comment Share on other sites More sharing options...
mrshelby2 Posted February 13, 2008 Author Report Share Posted February 13, 2008 Thanks, I was getting the same errors as Pretzel was and thought I was doing something wrong Mr S. Link to comment Share on other sites More sharing options...
Pastor Passum Posted February 14, 2008 Report Share Posted February 14, 2008 Thanks, I was getting the same errors as Pretzel was and thought I was doing something wrong Mr S. You aren't doing anything wrong Mr. Shelby 2. I've been asking about this function not working for about 4 weeks now. Hopefully someday Jim Link to comment Share on other sites More sharing options...
