Drive Shaft
i do not no the dr. shaft speed but if you are not racing then there is not really any reason for changing the shaft unless you want quicker accerleration from takeoff. the biggest advantage to the swap is that the aluminum shafts are about half the weight of the steel shafts and this makes the shafts turn more freely.most companies advertise you can get about a tenth of a second better time in the quarter.i called coast driveline in calif. and they said they have no clearance issues with there four inch shaft.the price of the shaft is about 700.00 bucks.with our shelbys being lowered you also havr to buy for about 300.00 a part that that you attach to the rear which is some type of link that keeps the shaft from running at an angle. i am comtemplating having this done .the reason why we have a 2 piece shaft is because of the vibration. coast told me there is no vibration on there aluminum shafts and they race there cars. good luck.
Thank you. I was curious if the current drive shaft is safe for that occasional burst to 140+. I understand the aluminum shaft frees up about 10 HP. I know the drive shaft loops are recommended for racing but 140+ is racing speeds.
The driveshaft on the SGT is well suited for high speeds. The reason it's a two piece is to reduce the chance of explosion from critical speed - the speed at which the driveshaft comes apart at the seams. Being two small pieces the critical speed is very high. On the one piece the critical speed is much lower but before the other forum was closed, stats on the coast shaft were posted and it was safe. I think critical speed was ~ 7000 rpm (engine rpm/drive gear ratio) or ~150+ mph. I know the numbers say it's ok and there are quite a few guys running the one piece shaft but I had a shaft explode in the middle from hitting critical speed on a Dodge truck. I will stick with the two piece.
Also there have been clearance issues with a 4" shaft. It's recommended not to go bigger than 3 1/2".
  • 3 weeks later...
I cant get the 4" DS to clear!
