07SHELBY GT Posted October 28, 2007 Report Share Posted October 28, 2007 Go to WWW,QUANTUMMOTORSORTS.COM,These guys offer a bolt on brake cooling set-up that allows you to keep your original wheels,And brake set-up.No doubt that a nice larger brake system and wheel upgrade would be better!But since I plan to try out a road course,Can't afford a Big Brake kit,I thought I would give you guys info that I found,Stock mustang GT,One of these cooling kits,Factory rotors,which we already have,And Hawk pads have been getting one guy Awesome results on a road course,Probably help on some high speed street driving.Looks as if you only have to remove the outer grills on the lower facia for the inlet ducts,No cutting I'm pretty sure.Going to order some this week. Link to comment Share on other sites More sharing options...
clark17357 Posted October 28, 2007 Report Share Posted October 28, 2007 Hey '07, Thanks for posting that information. I know I decided against the big brake kit when I found out I had to go to 20" wheels. Just not my style. Others have posted where to buy cross drilled and slotted rotors that bolt on. I am having the brake cooling kit from SAI installed so, between all that, I should be pretty close to where I need to be in braking for a road coarse. Did you think about alternate rotors? I recall them being something like $350 with shipping for all four corners. Jim Link to comment Share on other sites More sharing options...
07SHELBY GT Posted October 28, 2007 Author Report Share Posted October 28, 2007 Hey '07, Thanks for posting that information. I know I decided against the big brake kit when I found out I had to go to 20" wheels. Just not my style. Others have posted where to buy cross drilled and slotted rotors that bolt on. I am having the brake cooling kit from SAI installed so, between all that, I should be pretty close to where I need to be in braking for a road coarse. Did you think about alternate rotors? I recall them being something like $350 with shipping for all four corners. Jim Not really,But will investigate that.Thanks !I am trying to do as much as I can on the less expensive side,And did not want to change my wheels as I really like them! Link to comment Share on other sites More sharing options...
SGT2666 Posted October 28, 2007 Report Share Posted October 28, 2007 I've been thinking I'm going with braided liines for feel, some better pads and the cooling kit when available. The big brake kits really limit your wheel choices and I'm not racing anyway. I did see drilled and slotted rotors for our cars from baer that were pretty reasonable, I think they look pretty sharp if you have a wheel that show them off. Link to comment Share on other sites More sharing options...
pottydr_merged Posted October 28, 2007 Report Share Posted October 28, 2007 I have about 300 in the pads and rotors, Also bought the caps from Shelby Link to comment Share on other sites More sharing options...
69dejavue Posted October 28, 2007 Report Share Posted October 28, 2007 what pads and rotors do you have and what improvement, if any, have you noticed. Link to comment Share on other sites More sharing options...
07SHELBY GT Posted October 28, 2007 Author Report Share Posted October 28, 2007 I have about 300 in the pads and rotors, Also bought the caps from Shelby VERY NICE! Link to comment Share on other sites More sharing options...
ilmor Posted October 28, 2007 Report Share Posted October 28, 2007 I would go with slotted in lieu of drilled because I read often that drilled have a tendency to crack over time. I think just a switch to Hawk pads should be sufficient and that's what I plan to do prior to SAAC 33 next year. I might take a look at installing a homemade brake duct installation also, like I used to do on my race car; it may not be pretty but it may help. Link to comment Share on other sites More sharing options...
SGT2666 Posted October 29, 2007 Report Share Posted October 29, 2007 I would go with slotted in lieu of drilled because I read often that drilled have a tendency to crack over time. I think just a switch to Hawk pads should be sufficient and that's what I plan to do prior to SAAC 33 next year. I might take a look at installing a homemade brake duct installation also, like I used to do on my race car; it may not be pretty but it may help. So have you noticed a good improvment ? I have about 300 in the pads and rotors, Also bought the caps from Shelby Is there a noticable improvement ? Car looks great !! Link to comment Share on other sites More sharing options...
pottydr_merged Posted October 29, 2007 Report Share Posted October 29, 2007 So have you noticed a good improvment ? Is there a noticable improvement ? Car looks great !! thanks... I have never had to get on the brakes so bad that I woud have noticed the difference, I got them for looks, I didnt like the plain rotors, rust was showing, so I changed them, here is the set I bought http://www.irotors.com/storefrontprofiles/...052&i=233278093 Link to comment Share on other sites More sharing options...
07SHELBY GT Posted October 29, 2007 Author Report Share Posted October 29, 2007 thanks... I have never had to get on the brakes so bad that I woud have noticed the difference, I got them for looks, I didnt like the plain rotors, rust was showing, so I changed them, here is the set I bought http://www.irotors.com/storefrontprofiles/...052&i=233278093 Thanks for the link! Link to comment Share on other sites More sharing options...
clark17357 Posted October 29, 2007 Report Share Posted October 29, 2007 Thanks for the link! My thanks also to pottydr for the same link a few weeks ago. I ordered the same rotors and hope to have them this coming week. Jim Link to comment Share on other sites More sharing options...
blueshawk Posted October 29, 2007 Report Share Posted October 29, 2007 Go to WWW,QUANTUMMOTORSORTS.COM,These guys offer a bolt on brake cooling set-up that allows you to keep your original wheels,And brake set-up.No doubt that a nice larger brake system and wheel upgrade would be better!But since I plan to try out a road course,Can't afford a Big Brake kit,I thought I would give you guys info that I found,Stock mustang GT,One of these cooling kits,Factory rotors,which we already have,And Hawk pads have been getting one guy Awesome results on a road course,Probably help on some high speed street driving.Looks as if you only have to remove the outer grills on the lower facia for the inlet ducts,No cutting I'm pretty sure.Going to order some this week. Are you sure these fit the Shelby GT/California Special front fasica? I seem to recall that the openings for the brake duct panels are different than the regular GT. Link to comment Share on other sites More sharing options...
