shelbydream1 Posted October 20, 2007 Report Share Posted October 20, 2007 Has anyone with a lower grille found a no drilling front license plate bracket that is compatible?? All of the no drilling ones I've found are not compatible-was just wondering if anyone else had better luck. Link to comment Share on other sites More sharing options...
SoDakMac Posted October 20, 2007 Report Share Posted October 20, 2007 Well, yes and no. I purchased Craig Broussard’s bracket before my SGT arrived with the lower grill so I was not aware that I needed access in the lower grill area to make the bracket work as designed. However, I did make it work. The upside is that I did not have to drill any holes and the downside is that it is not as easily removed as it would be without the grill. I removed all the bracket bolts and worked the bracket between the lower grill and bumper fascia and then bolted on the bracket from the rear. To access the lower grill area from underneath you have to remove the “shield” that runs from the lower bumper fascia rearward. But, that is no big deal. It takes longer to install and it would take you 10-15+ minutes to remove but it saved drilling any holes. Link to comment Share on other sites More sharing options...
clark17357 Posted October 20, 2007 Report Share Posted October 20, 2007 Well, yes and no. I purchased Craig Broussard’s bracket before my SGT arrived with the lower grill so I was not aware that I needed access in the lower grill area to make the bracket work as designed. However, I did make it work. The upside is that I did not have to drill any holes and the downside is that it is not as easily removed as it would be without the grill. I removed all the bracket bolts and worked the bracket between the lower grill and bumper fascia and then bolted on the bracket from the rear. To access the lower grill area from underneath you have to remove the “shield” that runs from the lower bumper fascia rearward. But, that is no big deal. It takes longer to install and it would take you 10-15+ minutes to remove but it saved drilling any holes. Thanks for the information. I, too, have Craig's bracket and have not installed it yet because the lower grill is going to be installed on my car. I contacted Craig and he said you could get it done but that it would take more effort. I still think his product is the best thing going. Jim Link to comment Share on other sites More sharing options...
jaydub Mach1 Posted October 20, 2007 Report Share Posted October 20, 2007 Try this..... http://www.stangsunleashed.com/forums/inde...?showtopic=8280 Link to comment Share on other sites More sharing options...
clark17357 Posted October 20, 2007 Report Share Posted October 20, 2007 Try this..... http://www.stangsunleashed.com/forums/inde...?showtopic=8280 That is the bracket shelbydream1 and I have from Craig. Does your Dad's car have the lower grill? That is what makes the install a challenge. Jim Link to comment Share on other sites More sharing options...
Webba Posted October 21, 2007 Report Share Posted October 21, 2007 I have the lower grill and no bracket. I need to get one as we are required to have it in Maine. I posted a story a week or two ago about getting pulled over and forgot to tell you guys that the cop walked to the front of my car, looked down at the bumper and then left and right loking for a plate. He walked back to my window and never said a word. I figured I was getting a speeding ticket and no plate. I got a verbal warning. I forgot to buy lottery tickets that night. I am going to make a bracket this winter. I am in the machining field. Ill post pics when it is done. Link to comment Share on other sites More sharing options...
