Mustang Lover Posted October 4, 2007 Report Share Posted October 4, 2007 Right after I purchased my new Shelby I noticed there was a sound coming from the rear end area when I would go over a road surface that had dips in it , it sounded like a bad lower control arm bushing. I looked underneath the car and down on the sway bar where the Billet arm comes down there is a poly bushing and it had a grease fitting . after looking at it a couple of minutes I could tell there was no grease on this at all so I whipped out the grease gun with some moly lube and greased her up . Man those suckers were dry , but after greasing them up she was nice an quiet . i just wanted to let you guys know in case you run in to the same problem . Link to comment Share on other sites More sharing options...
mffarrell Posted October 5, 2007 Report Share Posted October 5, 2007 Right after I purchased my new Shelby I noticed there was a sound coming from the rear end area when I would go over a road surface that had dips in it , it sounded like a bad lower control arm bushing. I looked underneath the car and down on the sway bar where the Billet arm comes down there is a poly bushing and it had a grease fitting . after looking at it a couple of minutes I could tell there was no grease on this at all so I whipped out the grease gun with some moly lube and greased her up . Man those suckers were dry , but after greasing them up she was nice an quiet . i just wanted to let you guys know in case you run in to the same problem . Was there a churping/squeaking like sound? Link to comment Share on other sites More sharing options...
Mustang Lover Posted October 5, 2007 Author Report Share Posted October 5, 2007 Was there a churping/squeaking like sound? Yes only on roads with a dip , on a smooth surface it made no noise . Link to comment Share on other sites More sharing options...
mffarrell Posted October 5, 2007 Report Share Posted October 5, 2007 Yes only on roads with a dip , on a smooth surface it made no noise . I will check mine tomorrow. Thanks for the tip! Link to comment Share on other sites More sharing options...
robsdad3423 Posted October 5, 2007 Report Share Posted October 5, 2007 My Wrench founf the same thing, and greased it up. But Stil have a rattle. passenger side exhaust been back at the deal 3 times no better. Link to comment Share on other sites More sharing options...
stg Posted October 5, 2007 Report Share Posted October 5, 2007 My Wrench founf the same thing, and greased it up. But Stil have a rattle. passenger side exhaust been back at the deal 3 times no better. On the pass. side ,there is a L shape bracket att. to the top part of the muffler, it slides into the bracket ,, mine was to long , it is rubbing the rear bumper ,have the dealer check this, they remove the muffler and cut about 1/2 in from the L bracket, that is it , CHECK BOTH SIDES Link to comment Share on other sites More sharing options...
SGT1171 Posted October 5, 2007 Report Share Posted October 5, 2007 At first service the mechanic noticed the fittings and greased them. There are two fittings on the front suspension also. Link to comment Share on other sites More sharing options...
mffarrell Posted October 6, 2007 Report Share Posted October 6, 2007 Right after I purchased my new Shelby I noticed there was a sound coming from the rear end area when I would go over a road surface that had dips in it , it sounded like a bad lower control arm bushing. I looked underneath the car and down on the sway bar where the Billet arm comes down there is a poly bushing and it had a grease fitting . after looking at it a couple of minutes I could tell there was no grease on this at all so I whipped out the grease gun with some moly lube and greased her up . Man those suckers were dry , but after greasing them up she was nice an quiet . i just wanted to let you guys know in case you run in to the same problem . I checked the rear and front (2 on each side), 3 of them were bone dry...never had any grease ever applied. I still have a "churping" noise sound, and I am not sure what it could be. There is a churping sound when I go over bumps, and is more prominent when the engine is at normal temp. It is quiet when cold. It sure sounds like it is coming from the suspension. I did fix the exhaust issues, and I don't see any of the exhaust system rubbing. Somebody mentioned that two muffler hangers on our call are inferior to MY 2005-06. It could be anything, but it's not bad enough to take a risk and have a dealer try to fix it, yet. Link to comment Share on other sites More sharing options...
