Front end rattle slow speeds
So my front end rattles at slow speed, I am not bothered by the noise as i have built a few hot rods and noises are par for the course on a modified car, I just want to make sure everything is cool at hwy or track speeds ya know what I'm sayin? So do you all hear it too? Thanks!
It could be the infamous upper strut mount rattle that many of the 05-07's have.
http://www.mustangforums.com/m_2297319/tm.htm
I am geeting a chirping sound on the driver's side, but haven't been able to find it yet.
I remember reading in the Shelby manual that rattles and squeaks are not covered under warranty because of the FRPP suspension being stiffer and thus causing more rattles and such.
Clunking and such noises are signs of something loose and should be looked into.
Try checking the point where the hood pin rod meets the plate. If the pin is touching the stainless plate bolted on top of the hood it will rub and make a squeaking sound. At least it does on mine. You can also push down on the front drivers side corner of the hood and it will flex a little and make that same noise. It looks like who ever drilled the hole for the plate was off a little and put the plate to close to the pin and it rubs. Eventually it will wear a little spot and not squeak. It is not really visible though. Not sure if this is what your problem is, but it may give you a place to look.
The cold air kit ,near the back where it says FORD RACEING moves up and down a little ,use anothe pop ript. near the back close to the frender
As others have already mentioned, a front rattle is not something I notice at all. Mine is solid and operates without noise. Backing out of my driveway and down off the 2" curb at an angle, produces a slight creek on the strut. This is normal and it's is due to the stiff performance parts from Ford.
