rear bumber cover loose at bottom
clawsonbob
My rear bumber cover is very loose at bottom edge ...appears there is/was a plastic tab there that should have supported bottom edge better.
anyone else with this issue or oics of plastic tab in place ?
my bumber cover feels about ready to flop off at highway speed
thanks
bob
thanks
bob
If I remember correctly, there are three tabs, one on each side and one in the middle and they are held to the car with a plastic retainer. When I was playing with the exhaust, I noticed my middle one was a little loose but not enough to make a difference. If you're missing that middle tab, it could cause you a big problem as that is the only support I could find for the bumper cover.
thanks
bob
Look under the rear bumper ,, center tab remove it ,go back just a hair towards the front of the car ,drill a pilot hole SMALL !!! then pull the bumper towards the front of the car, use a small sheet met. screw, I have had no more problems ,also I had to take off the metal tag frame REAR and replace it with plastic good luck
