Shelby CS6 Upper Grille Instructions
Budman340
Hi all!!!!!!!!
Here is the last one for now. Hopefully more to come.
Thank you!!!!!
Bud
PREP STOCK GRILLE
Remove stock grille from car
Cut center section out of stock grille (area open to allow air through to radiator)
Cut the paper template along solid line
Lay stock grille face down, align template with end of grille and mark three holes
Turn template over and repeat on other end of stock grille
Drill the upper and lower holes on both ends to 5/16” (template states 5/8” hole)
Drill both center holes with a 4” hole saw
PREP SHELBY GRILLE
NOTE: If installing SHELBY letters on trunk lid, use the grille letter backing plate as a template before continuing with the grille assembly. Insure it is right side up and out before drilling.
Use letters “E” and “L” through the front of the Shelby grille to center the backing plate
Carefully bend the backing plate so the letters remain level
Drill the backing plate guide holes slightly smaller than the letter’s barrel nuts
Insert the barrel nuts in the backing plate
Center the backing plate behind the Shelby grille
Carefully insert the letter from the center out, adjusting as necessary to keep them level
INSTALL SHELBY GRILLE
Remove the outer nut from each stud on the Shelby grille
Install Shelby grille to stock grill, adjust inner nut on each stud until grille sits firm
Install the previously removed nuts on the four studs and tighten
INSTALL DRIVING LIGHTS
Place the new grille assembly face down
Loosely set the driving light in the oval opening, attached bracket facing top of grille
Position the appropriate Shelby supplied light bracket over the light’s bracket
(Shelby bracket is left or right specific. Short flange is positioned to the inside)
Mark supplied bracket, drill and loosely mount the light’s bracket to the supplied bracket
Reposition the driving light over the oval hole (adjust light bracket to Shelby bracket fit as necessary)
Drill two 1/8” holes on both sides of the supplied bracket into the stock grille
Attach the supplied brackets with four 1/8” aluminum rivets
Repeat on other side
FINAL STEPS
Reinstall new grille to the car
Wire the driving lights following the lights instruction sheet
This is the template for the driving lights.
Shelby_Upper_Grille_Template.jpg?t=1176576248
  • 5 years later...
Hey Budman340 ---- Just got a CS6 Upper Grille, how much did you cut away from the stock grille for the installation? Any suggestions of the best tool to do the cutting? Any idea if the CS6 lower grill will fit a stock V6 facia (I tried asking someone at Shely Performance ,,, all they can tell me is whether it's in stock.....) Your template for the upper grill install is great!
