Lower Billet Grille Instructions
Hi all!!!!!! Its me again!!!
Here are the instructions for the lower billet grille. Pictures will soon follow.
First, remove the two lower outer “faux” grille pieces. They will pop out. Look at the new lower grille insert, you will see on the brace a hole on each side. This is the hole where you will need to drill later. Now take the grille and place it in the opening, going in from behind the fascia. Now drill through the hole in the brace and through the fascia. Use 2 pop rivits to hold it in place. You can use a 1/8 by 1/2 inch pop rivit.
Now, snap back on the two “faux” grille pieces. The lower grille insert is now completed
  • 1 year later...
Thanks for posting this!
