broadcast sheet
usndvr79_merged
Do mfgs still put broadcast sheets in the car? If so where? Thanks
Do you mean "Build Sheets"? If so they can be anywhere. I do know someone that has theirs from a 2006, it was under the passenger seat. Another person, 2004, found it taped under the rear bumper. There is no set rule and they're not required to leave it anywhere. If you can find it great...sometimes it's even under the carpet because that's where someone dropped it before the carpet was installed. Anyway, if you can find it GREAT, but don't take your car apart looking, chances are these days it's not there.
Your parts dept can get you something WAY more detailed than the broadcast sheet. They can pull it right off Fords computer. It's about 30 pages and lists virtually every nut and bolt on the car. It's called the
HVBoM - Historical Vehicle Bill of Material.
Here's a small sample:
ENGINEERING PART SERVICE PART MTRCRAFT QTY DESCRIPTION COLOR DESC
V247V Not Serviced 1
7S837BB 7R3Z6007A 1 ENGINE ASY
6W731012BA 6W7Z1012BA 20 NUT - WHEEL
4R331125BD 4R3Z1125BA 2 ROTOR ASY
3W3D1508AB Not Serviced 4 CASING-TIRE 235/50R18 97W-G KDWS
5U5A1532AA 5U5Z1532A 1 DECAL
7R332078AA 7R3Z2078C 1 HOSE ASY - BRAKE
7R332269AB 7R3Z2269A KK19 1 TUBE ASY
7R332450KB 7R3Z2455L 1 PEDAL ASY - BRAKE
7R332780AA 7R3Z2780B 1 LEVER ASY - PARKING BRAKE
7R333200CB Not Serviced 1 STNG GR & LNKG ASY
6R333600CF35B8 6R3Z3600CAA 1 WHEEL ASY - STEERING CHARCOAL BLACK
Or the abbreviated version:
HVBoM - Features for VIN : 1ZVHT82H675291335
Model Year: 2007 Vehicle Line: VL ZF
Company Car: N Vehicle Body/Cab: FORD MUSTANG 2-DR COUPE GT
Engine Serial Number: 120620023407 Engine Tag Number: 7S837BB
Vehicle Calibration Number: 7ZF2U80A Production Date: 02-JAN-2007
Warranty Start Date: Warranty End Date:
DSO Number: EUR Paint Code:
Selling Dealer Code: 03608 Fleet Code:
Transmission Serial Number: 12260603966 Interior Trim Code: KW
Exterior Paint Code: UA Tu-Tone Paint Code:
Feature Description Table
Feature Code Feature Description
AIR BAG RESTRAINT - DRIVER
CPGAB AIR BAG RESTRAINT-DRIVER
AIR BAG RESTRAINT - PASS
CPHAB AIR BAG RESTRAINT-PASS
AMBIENT TEMP/SPEED PACK
ABTAA LESS AMBIENT TEMP/SPEED PACK
APPEARANCE PACKAGES
YPJAA LESS APPEARANCE PACK
YPJ01
AUDIO - RADIO FREQUENCY
IBMAB NAAO RADIO FREQUENCY
AUDIO - RADIOS
IBAFC CDX6+ RAD W/ SP SENS VOL CONTR
IBA00 ALL RADIOS
IBA02 ALL NON CASSETTE RADIOS
IBA03 ALL STEREO RADIOS
IBA05 ALL RADIOS WITH CD PLAYER
AUDIO - SOUND SYSTEM
IDAAH SUBWOOFER/AMP. SOUND SYSTEM
AUDIO - TYPE OF AUDIO BROADCAST
IBYAD SATELLITE DIGITAL BROADCAST
AXLE - FINAL DRIVE RATIO - SINGLE SPEED
EGAHD 3.55 FINAL DRIVE RATIO
EGA01 ALL SINGLE SPD FINAL DR RATIOS
AXLE DIFFERENTIAL - REAR
EGJAC LIMITED SLIP REAR AXLE
B&A CONTROL CODES (9270)
TAQA3
TARAE
BATTERIES
HTAAB STANDARD DUTY BATTERY
BLUE TOOTH HAND FREE CONNC-FIA
FITAA LESS BLUE TOOTH HAND FREE-FIA
BODY STYLE
BS BJ 2 DOOR COUPE-4 LITE
BRAKES - ANTI SPIN TRACTION
FEFAB ANTI-SPIN TRACT BRAKES W/O IVD
BRAKES - ANTI-LOCK
FEAAB 4 WHL ANTI-LOCK BRAKES
BRAKES - ANTI-LOCK ABS/TRACTION CONTROL
YCXAB MRKT CB-ABS/TRAC CONT
YCX01
CARGO NET-FIA
FIRAA LESS CARGO NET-FIA
CENTER CAPS-FIA
FIFAA LESS CENTER CAPS-FIA
CLIMATE - AIR CONDITIONING
AC B MANUAL AIR CONDITIONER
AC 1 ALL AIR CONDITIONING
CONVENIENCE GROUP
AAMAA LESS CONVENIENCE GROUP
DRIVE
DR B 2 WHL L/H REAR DRIVE
DR T ALL 2 WHEEL LEFT HAND DRIVE
DR 1 ALL LEFT HAND DRIVE
DR 2 ALL 2 WHEEL DRIVE
DR 6 ALL REAR WHEEL DRIVE
ENGINE
EN HZ MOD 4.6L 3V OHC VCT NA ALV8
EN 0G ALL GAS/GASEOUS ENGINES
EN 0M ALL MOD 4.6L GAS ENGINES
EN 08 ALL 8 CYLINDER GAS ENGINES
ENGINE - EMISSION REQUIREMENTS
DGAAC CALIFORNIA/GREEN STATE REQ.
ENGINE - HEATER
DEBAA LESS IMMERSION HEATER
ENGINE COVER - UNDER HOOD
C7SAA LESS ENGINE COVER - UNDER HOOD
EXHAUST TIPS
F2EAA LESS EXHAUST TIPS
EXHAUST TIPS-FIA
FIEAA LESS EXHAUST TIPS-FIA
EXTERIOR APPEARANCE GROUP
AB2AA LESS APPEARANCE GROUP
EXTERIOR PAINT - ACCENT STRIPE - BODYSID
CJPAA LESS ACCT STRIPE-BDYSD COLOR
CJRAA LESS BODYSIDE ACCENT STRIPE
EXTERIOR PAINT - ACCENT STRIPE - HOOD
CJTAA LESS HOOD ACCENT STRIPE
EXTERIOR PAINT - BLACK/SILVER EXTERIOR P
PNUAA EBONY SOLID C/C
EXTERIOR TAPE STRIPES-FIA
FIWAA LESS TAPE STRIPES-FIA
FLEET
YZKAA LESS FLEET
FLOOR MATS-FIA
FIDAA LESS FLOOR MATS-FIA
FOOT PEDAL DESIGN
GCEAE FOOTPEDALS-UNIQUE METALLIC FIN
FRONT VEHICLE COVER-FIA
FILAA LESS FRONT VEHICLE COVER-FIA
FUEL - ASSEMBLY PLANT FUEL FILL
FF1AB NORMAL FUEL FILL
FUEL ENGINE FUEL CAPABILITY
GBVAF UNLEADED FUEL CAPABILITY
GBV01 ALL NON FLEX FUEL CAPABILITY
GBV02 ALL GASOLINE FUEL CAPABILITY
FUEL FILLER DOOR-FIA
FINAA LESS FUEL FILLER DOOR-FIA
FUEL TANK LOCK
GBTAE NON LOCKG FUEL CAP W/BP LABEL
FULL VEHICLE COVER-FIA
FIPAA LESS FULL VEHICLE COVER-FIA
GENERIC COUNTRY GROUPINGS
SATAB GENERIC COUNTRY GROUP 1
GVWS
AAZBB 4450 LB. GVW
AAZ01 0 LB THRU 4580 LB GVW
AAZ06 0 LB THRU 8600 LB GVW
HOOD SCOOP
BLTAA LESS HOOD SCOOP
I/P INSERT
BBQAX I/P INSERT - DARK ALUMINUM
INSTRUMENTATION - CLUSTERS
HCFAQ INSTRUM CLUSTER-6 GAUGE
INSTRUMENTATION - MESSAGE CENTER
HKDAB MESSAGE CENTER
INSTRUMENTATION - SPEEDOMETERS
HDHAB MPH/KPH SPEEDOMETER
INTERIOR DECOR LEVEL
BBBAC INTERIOR DECOR-LEVEL A
INTERIOR FLOOR MATS - FRONT
BBHAA LESS FRONT FLOOR MATS
INTERIOR PACKAGES
A2TAA LESS INTERIOR PACK
INTERIOR TRIM COLORS - ALL
000DW CHARCOAL BLACK
LABELS - SPECIAL LANGUAGE
AEAAE ENGLISH LANGUAGE LABEL
LAMPS - FRONT FOG
JBKAB FRONT FOG LAMPS
LAMPS - HEADER LIGHTS - ROOF
JCGAF HEADER DOME LIGHT W/O MAP
LAMPS - HEADLAMPS - RUNNING
JBCAA LESS DAYTIME RUNNING LAMPS
LICENSE PLATE BRACKET - FRONT
CLVAD FRT LICENSE PLATE HOLDER DELUX
MARKET DERIVATIVE
MD F FORD DIVISION DERIVATIVE
MD 1 FORD & MERCURY MRKT DERIVATIVE
MARKETING BODY CODE
YBCCR MRKTG BODY CODE-T82
YBC01
MARKETING TRIM
YZTAC PREMIUM MKTG TRIM
YZT01
MIRROR - INTERIOR REAR VIEW
BSBBE PRISMATIC MIRROR
MK CB-DRV SEAT/HD REST/LUMBAR
YK1AB 6 WY PWR DRV ST/PWR LUMBAR
YK101
MODULE CONFIGURATION
TDAAW OVERSPEED WARNING DISABLED
TDABR REMOTE ENTRY W/KEY IN ENABLED
TDAB3 ABS/TC
TDADL N. A. PERIMETER ALARM ENABLED
TDAD9 DRL DISABLED
TDAFU GLOBAL WNDOW OPEN/CLOSE-ENABLE
TDAHC BODY SECUR. MODULE PRESENT
TDAHQ TRANSMISSION - MANUAL
TDAH9 CONVERTIBLE TOP - DISABLED
TDAME FRONT FOG LAMPS - ENABLED
TDANG DOOR AJAR TELLTALE-DISABLED
TDANH SHIFT INDICATOR LIGHT-ENABLED
TDANK SPEEDOMETER CALIBRATION-N.A.
TDANM KEY CYCLNDR LOCK/UNLOCK ENABLE
TDAN4 TPMS ENABLED
MOULDINGS - EXTERIOR MID BODYSIDE
BMBAA LESS EXTERIOR BODYSIDE MLDGS
MRKTG REGIONAL PKGS 1
YLAAA LESS MRKTG REGIONAL PKGS 1
OWNER HAND BOOK PACK
AEDAB OWNER HAND BOOK PACK
PLANT BUILD REQUIREMENTS
AAGCL FLATROCK ASSEMBLY PLANT - USA
PROGRAM CONTROL
AD6EB 2007 JOB #2 PROGRAM CONTROL
REMOTE STARTER-FIA
FIVAA LESS REMOTE STARTER-FIA
ROOF - ALL ROOF COLORS
R99Z9 NON/COLOR (ROOF)
ROOF - CONVERTIBLE BOOT - ROOF COVER
CHRAA LESS CONVERTIBLE BOOT-RF CVR
ROOF - LESS CONVERTIBLE ROOF
RZZZ9
RZZ00 LESS CONVERTIBLE ROOF
SALES OFFICES
AAHAB U.S. SALES
AAH01 U.S. AND CAN. SALES
AAH02 U.S., CAN. AND MEX. SALES
SEAT - FRONT SEAT TYPE
FS A SEAT-SPORT-DRV/PASS
SEAT - TEMP CONTROLLED DRIVER
BY1AA LESS TEMP CONTROL DRIVER SEAT
SEAT - TEMP CONTROLLED PASSENGER
BY2AA LESS TEMP CONTROL PASSNGR SEAT
SEAT ADJUSTER - DRIVER
BYPAC POWER 6-WAY DRIVER SEAT ADJUST
SEAT ADJUSTER - PASSENGER
BYQAB MANUAL 2-WAY PASS SEAT ADJUST
SEAT LUMBAR SUPT - DRIVER SEAT
BWRAC LUMBAR SEAT SUPT-DRIVER PWR
SEATS - MRKT CB-TEMP CONTR ST-DRV/PASS
YCLAA LESS MK CB-TEMP CONTR ST-DR/PA
SECURITY SYSTEMS
HNAAJ PERIM ALRM W/ INTRU&INCL SNSR
SIDE IMPACT PACKAGE
AB3AB SIDE IMPACT PACK
SIRIUS SAT RAD RECEP DURATION
YY1AA LESS SIRIUS SAT RAD RECEP SUBS
SMOKERS PACKAGE
J3CAA LESS SMOKERS PACKAGE
SPECIAL BUILD REQUIREMENT
AADAA LESS SPECIAL BUILD REQUIREMENT
SPECIAL BUILD REQUIREMENTS
SBRAA LESS SPECIAL BUILD REQUIREMENT
SPEED AUDIBLE WARNING DEVICE
HLIAA LS SPD AUDIBLE WARNING DEVICE
SPLASH GUARDS-FIA
FIMAA LESS SPLASH GUARDS-FIA
SPOILER - REAR
BPFAA LESS REAR SPOILER
SPRING - COIL LEFT FRONT
TAAU1 4R33 - 5310 -FA L/F COIL
SPRING - COIL LEFT REAR
TAEE2 5R33 -5560 -BA L/R COIL
SPRING - COIL RIGHT FRONT
TACL5 4R33-5310-FA R/F COIL
SPRING - COIL RIGHT REAR
TAGE2 5R33 - 5560 - BA R/R COIL
STEERING WHEEL
GTACC STRG WHL-LEA WRP/SATIN ALM SPK
GTA01 ALL LEATHER STEERING WHEELS
SUSPENSION - STABILIZER BAR - FRONT
DYKAC UPSIZED FRONT STABLIZER BAR
SUSPENSION - STABILIZER BAR - REAR
DZLAC UPSIZED REAR STABLIZER BAR
TERRITORIES - NORTH AMERICA PRINCIPLE
WANAB USA
WAN01 ALL U.S.A. AND CANADA
WAN02 USA,USA TERR,CAN,MEX
WAN03 ALL USA AND MEXICO
TIRE INFLATION KIT
HJBAB TIRE INFLATION KIT
TIRE SPARE
D3MAA LESS SPARE TIRE
TIRES - 18 INCH
D3HAG 235/50 ZR 18 TYRE
TPO/ORDER CODES 0-300
YZBAK TPO/ORDER CODE 140A
YZB01
TPO/ORDER CODES 600-999
YZDAA
YZD01
TRANSMISSION
TR SK 5 SPD MAN TRANS TR3650
TR 0M ALL MANUAL TRANSMISSIONS
TR 05 ALL 5 SPD MANUAL TRANSMISSIONS
VERSION
VS AX GT VERSION - CAR
VS 0S ALL EXCEPT SHO VERSION
VERSION PACKAGES
AACMC SPECIAL VEHICLE BUILD PACKAGE
VISOR - SUNVISORS - DRIVER
BCAAD SUNVISOR,SINGLE-DRV NON-ILLUM
VISOR - SUNVISORS - PASSENGER
BCBAD SUNVISOR,SINGLE-PAS NON-ILLUM
WHEEL - HUB COVERS
D5DB2 CTR HUB ORN-PONY LOGO/SPINNER
WHEEL - LOCKING LUG NUT KIT
D5HAB LOCKING LUG NUT KIT-WHEEL
WHEEL - SPARE
D17AA LESS SPARE WHEEL
WHEEL SIZE/STYLE - 18 INCH
D2UDH 18X8.5 BLACK PAINTED ALUM WHL
WHEELBASE
A2WAQ 107.1 CAR WHEELBASE
WINDOWS - REAR SIDE
B2DAF FIXED REAR SIDE WINDOW
ZF -A-L -VERONA/ABERDEEN-
2SKDW
2SK00 ZF -A-L -NUDO/ABERDEEN-
