2006GT500 Posted January 22, 2008 Report Share Posted January 22, 2008 I have noticed multiple small air bubbles on my passenger side stripe. If this happened to your car would you have Ford replace the stripe or just live with it? I'm not really sure I want to go through the trouble of having them take it off and then risk having them screw it up putting it back on. Link to comment Share on other sites More sharing options...
SkyPilot Posted January 22, 2008 Report Share Posted January 22, 2008 I have noticed multiple small air bubbles on my passenger side stripe. If this happened to your car would you have Ford replace the stripe or just live with it? I'm not really sure I want to go through the trouble of having them take it off and then risk having them screw it up putting it back on. I'd fix it-it is probably just going to get worse. And if you fix it sooner rather than later your chances of a better match are better because it will weather/age with the rest of them. Be careful they use the stripes for the right year-someone posted they were slightly different on some colors depending on the model year. Link to comment Share on other sites More sharing options...
phr3121 Posted January 22, 2008 Report Share Posted January 22, 2008 I have noticed multiple small air bubbles on my passenger side stripe. If this happened to your car would you have Ford replace the stripe or just live with it? I'm not really sure I want to go through the trouble of having them take it off and then risk having them screw it up putting it back on. I had a similar problem with two small bubbles. One I easily got rid of by pushing the air out by pressing on it (edge of stripe). The other I used a small needle to punch a small hole and pressing on it to get rid of the extra air. Link to comment Share on other sites More sharing options...
