carrera Posted January 21, 2008 Report Share Posted January 21, 2008 Anyone have any experience removing a shelby dash plaque once it is adhered to the dash. I installed one before I fell in love with the SS package and want to remove it to save before my car gets shipped to Shelby for the conversion. It's like when you got your girl friends name tattoed on your arm and then changed girl friends. Oh well! Link to comment Share on other sites More sharing options...
YZD263 Posted January 22, 2008 Report Share Posted January 22, 2008 I'd try a hair dryer or heat gun to try to loosen the glue, I'd use a thin plastic scraper you can buy at yout local Home Depot to gently get under the edge and start to pry it up gently. If you can't get the scraper in try fishing line that also works well. I've used both methods on fender emblems etc. and they worked great but I have never done this on a dash plaque. +1. The air dryer worked for me for the door sills and SHELBY lettering in the back. However, if this does not work, I would simply make sure that the folks at SAI slavage the current plaque when they do the conversion and install the new one; they probably will have that same request from many owners anyway. Link to comment Share on other sites More sharing options...
carrera Posted January 22, 2008 Author Report Share Posted January 22, 2008 Thanks . I'll keep you posted on my success Link to comment Share on other sites More sharing options...
ingram4868 Posted January 22, 2008 Report Share Posted January 22, 2008 Hair dryer and when it gets nice and warm slip a piece of fishing line behind it and with a sawing type action it will cut through the goop. Link to comment Share on other sites More sharing options...
sicilianjg Posted January 22, 2008 Report Share Posted January 22, 2008 Hair dryer and when it gets nice and warm slip a piece of fishing line behind it and with a sawing type action it will cut through the goop. +1 Link to comment Share on other sites More sharing options...
kstrong Posted January 22, 2008 Report Share Posted January 22, 2008 You could swap me for my dash piece. I bought a spare, sent it to get autographed before they offered a dash plaque. When I got my car the dealership swapped them out. Now I have an unsigned extra centre dash. Link to comment Share on other sites More sharing options...
oilman Posted January 22, 2008 Report Share Posted January 22, 2008 Hair dryer and when it gets nice and warm slip a piece of fishing line behind it and with a sawing type action it will cut through the goop. +1 Works VERY well, the hotter you can get it, the easier it will come off. Link to comment Share on other sites More sharing options...
chuckstang Posted January 22, 2008 Report Share Posted January 22, 2008 Id use the plastic putty knife, stay away from the fishing line as you may actually get the wire between the adhesive and the plaque, which will leave all the sticky adhesive on your dash! And that will not be easy to remove Link to comment Share on other sites More sharing options...
TexasShelby Posted January 22, 2008 Report Share Posted January 22, 2008 I just cut four corners of the adhesive cover (using about 1/4 of the adhesive tape and leaving the rest covered) in case i ever needed to remove it. Link to comment Share on other sites More sharing options...
Alexandros Posted January 23, 2008 Report Share Posted January 23, 2008 Anyone have any experience removing a shelby dash plaque once it is adhered to the dash. I installed one before I fell in love with the SS package and want to remove it to save before my car gets shipped to Shelby for the conversion. It's like when you got your girl friends name tattoed on your arm and then changed girl friends. Oh well! +1, hot air will loosen the glue...worked for me..... Link to comment Share on other sites More sharing options...
