Shelby Gauge pod
Ok I have the Shelby pod, the oil temp gauge never moves always at the bottom.
anyone else?
Mark
Mark did SAI install it? Has it ever worked? Something is seriously wrong. I would contact SAI if they installed it. We have it on ours, oil pressure and fuel pressure read as soon as you start the car. The boost gauge does not read until you punch it :hysterical2: 2500 rpm's. This is my wife's favorite feature of the car. :hysterical:
Hope this helps, keep us posted.
Dave
anyone else?
Mark
Mark,
I just had my gauge pod installed yesterday at SAI, and it behaves like yours. Oil temp. never goes above 140 F. The oil temp. should be at 180F - 200F at normal operation.
I have a email into SAI asking what's up with the low oil temp. reading.
Mark,
Mine was done by SAI when the dealer bought, let me know what SAI says!
Mark
Mark
OK - I think that there is definitely something wrong. How can your oil temp be that much lower than your water temp.? Oil temp should be close to water temp.; about 180F-200F
Currently, we're seeing average readings of 20* below engine coolant temp. This reading is being taken from a sending unit that is installed in a billet block (that is remotely mounted from the engine). In some cases, it takes a few minutes for the temp to register. Also, it's a cooler climate out so your ambient outside temp will affect the oil temp as well. Hope that helps a little.
I drove almost 600 miles non-stop, except a gas refill, and oil temp never got above 140F.
Same thing on mine. Oil temp, as measured by the guage runs cool. As said above the temp sensor is outside the block in a separate billet mounting point plumbed from the filter adapter. If you spend any time on the track, lots of hard pulling and high revs, you will see it climb so it's working. You're just going to have to remember it runs cool.
Todd
07SGT1638
Todd
07SGT1638
Ok I have just never seen the needel move, even after a hard drive...I will have to wait till summer and see.
Let uour car idle for 5-10 min, then the oil tem will climb to about 145F, when the outside air temp is 50F.
Try it!
Well I guess it is wattanty time again, the needle never moves, never even gets to 140, I sat in traffic today for 15 minutes and nothing...
Mark
