75coug Posted December 31, 2007 Report Share Posted December 31, 2007 I have read some mention of a problem with the hood pins on the '07 SGT, but nowhere did I see exactly the nature of the problem (is it a defect?) or why a fix is necessary. I apologize for my ignorance and would welcome some information on the subject. I did a couple of searches, but did not find a succinct topic on the subject. Thanks. Link to comment Share on other sites More sharing options...
mastersmech1 Posted December 31, 2007 Report Share Posted December 31, 2007 I have read some mention of a problem with the hood pins on the '07 SGT, but nowhere did I see exactly the nature of the problem (is it a defect?) or why a fix is necessary. I apologize for my ignorance and would welcome some information on the subject. I did a couple of searches, but did not find a succinct topic on the subject. Thanks. The only problem I have seen or read about with the stock SGT hoodpins is when the idiots, myself included, pop the hood without releasing the pins. This causes wrinkles in the pin plates. The questions and issues have been with the extensive modifications required to install the Shelby Billet style pins. Which, by the way , look great when installed. Link to comment Share on other sites More sharing options...
75coug Posted December 31, 2007 Author Report Share Posted December 31, 2007 The only problem I have seen or read about with the stock SGT hoodpins is when the idiots, myself included, pop the hood without releasing the pins. This causes wrinkles in the pin plates. The questions and issues have been with the extensive modifications required to install the Shelby Billet style pins. Which, by the way , look great when installed. I see. Thanks for the clarification. Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted January 1, 2008 Report Share Posted January 1, 2008 I have read some mention of a problem with the hood pins on the '07 SGT, but nowhere did I see exactly the nature of the problem (is it a defect?) or why a fix is necessary. I apologize for my ignorance and would welcome some information on the subject. I did a couple of searches, but did not find a succinct topic on the subject. Thanks. There is one issue with SOME early hood pin sets where the ring would pop from the pin when attempting to close it down on the plate. This was corrected in later versions and is covered under warranty and a "do-it-yourself" easy job! Heck I even did it! Other than that there are no known issues that I am aware of. -jeff Link to comment Share on other sites More sharing options...
stormeaston Posted January 1, 2008 Report Share Posted January 1, 2008 There wasn't really a problem with them................they were just cheap, you can buy the same set at any auto parts place for 19.99. The billet ones are much nicer, both with function and looks. Link to comment Share on other sites More sharing options...
Torrence Posted January 1, 2008 Report Share Posted January 1, 2008 If I'm not mistaken, they were rusting and scratching. I just ordered a new set from shelbyauto's for like 100 bucks, but they are back ordered. The pins look HOT! Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted January 1, 2008 Report Share Posted January 1, 2008 If I'm not mistaken, they were rusting and scratching. I just ordered a new set from shelbyauto's for like 100 bucks, but they are back ordered. The pins look HOT! The reports of rust were the 06 GT-H pin sets, I've never seen reports of rust on the stainless 07 sets. The scratching is more to do with not enough care when sliding in or out. The new ones are nice too but I like the look of the older ones. Link to comment Share on other sites More sharing options...
Hot Pony Posted January 1, 2008 Report Share Posted January 1, 2008 The only problem I have seen or read about with the stock SGT hoodpins is when the idiots, myself included, pop the hood without releasing the pins. This causes wrinkles in the pin plates. The questions and issues have been with the extensive modifications required to install the Shelby Billet style pins. Which, by the way , look great when installed. Ditto Link to comment Share on other sites More sharing options...
BUICK468 Posted January 5, 2008 Report Share Posted January 5, 2008 Before my SGT was sent to me the salesman told me he noticed that the hood pin hardware was bent. He pulled a set off of an 08' model that was setting on the show room and they actually look so much nicer. They have Shelby on them and look fairly expensive. Guess I got lucky. Link to comment Share on other sites More sharing options...
sdear Posted January 6, 2008 Report Share Posted January 6, 2008 Before my SGT was sent to me the salesman told me he noticed that the hood pin hardware was bent. He pulled a set off of an 08' model that was setting on the show room and they actually look so much nicer. They have Shelby on them and look fairly expensive. Guess I got lucky. You sure did ! Especially if your car is an 07, as the ones that say "Shelby GT " are exclusive to the 08's. The ones that you can order from SPP only say "shelby" . The billet ones are soooooooo much nicer. Link to comment Share on other sites More sharing options...
firechiefdale Posted January 6, 2008 Report Share Posted January 6, 2008 There is one issue with SOME early hood pin sets where the ring would pop from the pin when attempting to close it down on the plate. This was corrected in later versions and is covered under warranty and a "do-it-yourself" easy job! Heck I even did it! Other than that there are no known issues that I am aware of. -jeff Link to comment Share on other sites More sharing options...
firechiefdale Posted January 6, 2008 Report Share Posted January 6, 2008 What is the fix for the hood pins mine are coming apart also Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted January 7, 2008 Report Share Posted January 7, 2008 What is the fix for the hood pins mine are coming apart also Take it back to your dealer and have them file a warranty claim. Link to comment Share on other sites More sharing options...
7ONE7 Posted January 11, 2008 Report Share Posted January 11, 2008 Hello, all. The new model pins do look a lot better. Here's a picture of black on black. Link to comment Share on other sites More sharing options...
Pastor Passum Posted January 12, 2008 Report Share Posted January 12, 2008 Hello, all. The new model pins do look a lot better. Here's a picture of black on black. Hey 7, that really looks great. Would almost make me want to trade my white one for black Seriously...they look great. Thanks for posting the pic. Jim Link to comment Share on other sites More sharing options...
fatboy Posted January 14, 2008 Report Share Posted January 14, 2008 in reference of rust issue; i believe its from the nuts used on the pin threads...i believe the pins themselves are stainless but the nuts arent. my 07 has some rust around the threads but its from the nuts or maybe the mounting bracket where the pin goes through...one or the other or both......i guess Link to comment Share on other sites More sharing options...
Sharp GT500 Posted January 14, 2008 Report Share Posted January 14, 2008 On the 08's is the "Shelby" on top and the GT on bottom of the plate or is it like the one's 70NE7 has but with GT on the top? Or better yet, does anyone have a good picture of the 08 pins. Link to comment Share on other sites More sharing options...
bruces Posted January 20, 2008 Report Share Posted January 20, 2008 I had problems with o rings steel had Shelby replace them NC also replaced the plates with decent one from Branda 23.95 and they do not scratch or dent. Link to comment Share on other sites More sharing options...
Reino2 Posted January 20, 2008 Report Share Posted January 20, 2008 On the 08's is the "Shelby" on top and the GT on bottom of the plate or is it like the one's 70NE7 has but with GT on the top? Or better yet, does anyone have a good picture of the 08 pins. The say "Shelby" on top and "GT" on the bottom. Sorry no pics and from what I understand the only difference in the 08 and the new pins you can get from SPP is the ones from SPP dont have the "GT". The ones SPP has are currently on backorder. They should be shipping in about 2 weeks, I hope. Link to comment Share on other sites More sharing options...
