nachtkriechen Posted December 21, 2007 Report Share Posted December 21, 2007 When those of you that do store your cars for the winter, do you take any precautions for fuel lines clogging, or fuel going bad? And what about flat spots in the tires? Or are these problems that you only have to worry about if storing for a year or more? Thanks, - Josh Link to comment Share on other sites More sharing options...
90GT Posted December 21, 2007 Report Share Posted December 21, 2007 When those of you that do store your cars for the winter, do you take any precautions for fuel lines clogging, or fuel going bad? And what about flat spots in the tires? Or are these problems that you only have to worry about if storing for a year or more? Thanks, - Josh Stabil in the tank and then drive it a little to get it through the system. I also have a battery tender to prevent the battery from going dead. To prevent flat spots I park the car on three pieces of foam insulation under each wheel. Also make sure you have the tires properly inflated. Link to comment Share on other sites More sharing options...
07alloyGT Posted December 21, 2007 Report Share Posted December 21, 2007 When those of you that do store your cars for the winter, do you take any precautions for fuel lines clogging, or fuel going bad? And what about flat spots in the tires? Or are these problems that you only have to worry about if storing for a year or more? Thanks, - Josh Ship it to SS in Florida. He'll take care of it for the winter. Link to comment Share on other sites More sharing options...
shel-b001 Posted December 21, 2007 Report Share Posted December 21, 2007 Clean the car , wash wax, vacuum ,check all fluid levels, put stabil in gas. I start mine on a nice day move it out of the garage to get oil on all moving parts & stop it at a different spot after pulling it back into the garage. Link to comment Share on other sites More sharing options...
KobraII Posted December 21, 2007 Report Share Posted December 21, 2007 As for flat spots on the tires, my father has the best thing for that. Burnouts! Link to comment Share on other sites More sharing options...
Alloy Dave Posted December 21, 2007 Report Share Posted December 21, 2007 Stabil in the tank and then drive it a little to get it through the system. I also have a battery tender to prevent the battery from going dead. To prevent flat spots I park the car on three pieces of foam insulation under each wheel. Also make sure you have the tires properly inflated. I just run the car for 10 minutes once a month. Not sure what you mean by "clogging", I've NEVER heard of a fuel line clogging. What would it clog with? The varnish is simply a surface thing....I don't think there's any way that would "clog" a line, even over many many years. As for flat spots, this has been hotly debated and I've been flamed for my response. I have a 1969 Camaro, and put tires on it in 1982. I just had those tires dismounted last week as I'm restoring the car. The tires have sat on the ground for 25 years, as I only drive the car 500 miles/year, and the tires have zero flat spots. I worked at a brake/tire shop for 6 years in the mid '80s, and I've NEVER seen a tire flat spotted from sitting (I have seen flat spots due to other issues such as misaligned toe on the rear end of some cars), yet there are wegsites out there that will attempt to scare people by mentioning the flat spotting issue. You believe what you want, but I firmly believe there is ZERO risk of flat spotting tires just from sitting. Dave Link to comment Share on other sites More sharing options...
nachtkriechen Posted December 21, 2007 Author Report Share Posted December 21, 2007 I just run the car for 10 minutes once a month. Not sure what you mean by "clogging", I've NEVER heard of a fuel line clogging. What would it clog with? The varnish is simply a surface thing....I don't think there's any way that would "clog" a line, even over many many years. As for flat spots, this has been hotly debated and I've been flamed for my response. I have a 1969 Camaro, and put tires on it in 1982. I just had those tires dismounted last week as I'm restoring the car. The tires have sat on the ground for 25 years, as I only drive the car 500 miles/year, and the tires have zero flat spots. I worked at a brake/tire shop for 6 years in the mid '80s, and I've NEVER seen a tire flat spotted from sitting (I have seen flat spots due to other issues such as misaligned toe on the rear end of some cars), yet there are wegsites out there that will attempt to scare people by mentioning the flat spotting issue. You believe what you want, but I firmly believe there is ZERO risk of flat spotting tires just from sitting. Dave Thanks, everyone for all of the great info! :happy feet: Dave, maybe it has to do with environment? I have personally witnessed flat spots in tires (from sitting for a long time). I've had it happen to a motorcycle I owned, as well as a friends car that sat in my driveway for a long time. As well, the same motorcycle had gas issues after a year and a half of sitting. It wouldn't start to save it's life. After replacing the gas with a fresh tank, and running it through the lines, it started right up. This could also be the gas station where we got it, but, the old gas had sediment in it. I doubt it was from dirty lines on the bike, but, that's also a remote possibility. - Josh Link to comment Share on other sites More sharing options...
90GT Posted December 22, 2007 Report Share Posted December 22, 2007 I just run the car for 10 minutes once a month. Not sure what you mean by "clogging", I've NEVER heard of a fuel line clogging. What would it clog with? The varnish is simply a surface thing....I don't think there's any way that would "clog" a line, even over many many years. As for flat spots, this has been hotly debated and I've been flamed for my response. I have a 1969 Camaro, and put tires on it in 1982. I just had those tires dismounted last week as I'm restoring the car. The tires have sat on the ground for 25 years, as I only drive the car 500 miles/year, and the tires have zero flat spots. I worked at a brake/tire shop for 6 years in the mid '80s, and I've NEVER seen a tire flat spotted from sitting (I have seen flat spots due to other issues such as misaligned toe on the rear end of some cars), yet there are wegsites out there that will attempt to scare people by mentioning the flat spotting issue. You believe what you want, but I firmly believe there is ZERO risk of flat spotting tires just from sitting. Dave Read my post again, I never said any thing about clogging. All I said was I put Stabil in the tank. Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 23, 2007 Report Share Posted December 23, 2007 Winter? Link to comment Share on other sites More sharing options...
KobraII Posted December 24, 2007 Report Share Posted December 24, 2007 Winter? Yeah, yeah, yeah. Blah blah blah 60 degrees year round. Blah blah blah awesome beaches. Oh, and can't forget, weeeeeeeeeeeee Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 24, 2007 Report Share Posted December 24, 2007 Link to comment Share on other sites More sharing options...
Alloy Dave Posted December 24, 2007 Report Share Posted December 24, 2007 Yeah, yeah, yeah. Blah blah blah 60 degrees year round. Blah blah blah awesome beaches. Oh, and can't forget, weeeeeeeeeeeee Ready for a Mustang show this summer? You want to meet an "old" guy like me? Link to comment Share on other sites More sharing options...
DDT Posted December 24, 2007 Report Share Posted December 24, 2007 As for flat spots on the tires, my father has the best thing for that. Burnouts! Don't let your Father have all the FUN ????????? Link to comment Share on other sites More sharing options...
nachtkriechen Posted December 24, 2007 Author Report Share Posted December 24, 2007 Winter? Yep, there's this white stuff called "snow", that we get quite a bit of here in Utah, every year. Just a few days ago, we got 6" of snow fall in one night! Since I love snow boarding, and snow period, this isn't a problem. :happy feet: - Josh Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 24, 2007 Report Share Posted December 24, 2007 Yeah, yeah, yeah. Blah blah blah 60 degrees year round. Blah blah blah awesome beaches. Oh, and can't forget, weeeeeeeeeeeee Stop 'in! You've got an open invitation to visit us out here. Take a ride and we'll take a weeeeeeeeeeeeeee ride! :happy feet: Link to comment Share on other sites More sharing options...
KobraII Posted December 24, 2007 Report Share Posted December 24, 2007 Ready for a Mustang show this summer? You want to meet an "old" guy like me? Hell yeah! I can't wait. It'd be even better if we could ride up together, but that'd be close to impossible Link to comment Share on other sites More sharing options...
KobraII Posted December 24, 2007 Report Share Posted December 24, 2007 Don't let your Father have all the FUN ????????? I try not to. But when he gets behind the wheel, he's young again, and he's tons of fun then! Link to comment Share on other sites More sharing options...
KobraII Posted December 24, 2007 Report Share Posted December 24, 2007 Stop 'in! You've got an open invitation to visit us out here. Take a ride and we'll take a weeeeeeeeeeeeeee ride! :happy feet: I'd really love to come down and get out of here. It's 40 degrees here, and I'm finally getting over my cold Link to comment Share on other sites More sharing options...
RUFDRAFT Posted December 25, 2007 Report Share Posted December 25, 2007 Link to comment Share on other sites More sharing options...
