Hooking up
dqron
I put on that Steeda stop the hop kit and I'm not sure if its the cold weather, the tires, or this kit, but I'm having a hard time getting it to hook up. If I jump on it in 1st or 2nd my tires just spin. I love not having the wheel hop but would like it to hook up a little better. Is it the weather or this kit that causes this?
Thanks
Ron
Thanks
Ron
If it's cold you won't hook up. There's even a warning in the manual that the stock tires aren't designed for weather below 40 degrees. See how it hooks up when it's 75 degrees.
Don
As ShelbyRookie stated, it is the cold weather. These F1 tires have a soft compound for better traction during warm temps but when the cold sets in they get as hard as a rock and your traction becomes very iffy. If you need to drive in a cold climate you'll need to switch to all season or snow tires.
Don
It is in the 30's here. Should that traction control be kicking in, instead of just spinning?
The way SVT programmed this TCS it doesn't really do much with a heavy throttle application. They "wanted" to let us spin the tires and do burn-outs. The GT500 TCS was programmed more for control under steady throttle driving conditions, although when it DOES kick in in situations like you are talking about, I have experienced some serious bogging on the couple of occassions when I did go to the 1320' track (and forgot to turn TCS off). That was before my suspension mods and the bogging was right after the wheel hop had stopped and the tires hooked up.
The guys are right, for driving below 40 degrees you need different tires just to be safe.
Last night with temps around 40 ish, I got heavy into the throttle, traction control did not kick in and the rear end stepped sideways with original LCA and UCA's. Had to get off the throttle quickly for things to get back in control. Wasn't a pleasant experience.
Thx sprint200 for the GT500 TCS programming info. Just the info I was looking for.
