Fuel Gauge
GTEE500
Huh, you would have thought that by now, Ford would have ironed out the fuel tank/gauge/sending unit/vapor lock issues that the late model Mustang's have had since 2005.
GTEE, take the car in. 2007 Stang's and Shelby's had a couple (many?) of different fuel system problems one of which was false guage readings. It's an intermitant problem right? I will bet you that the problem ends up being a bad sending unit and not the gauge itself. In your case, I suspect that the float arm on the sending unit is bent, and probably got bent at the factory when it was being installed into the tank.
Warranty time.
