Do the 500's come with brembo brakes"
14" sounds very very nice! But I'd still be pushing for somthing better in the stock end or atleast larger.
Why? 90% of all braking is on the front wheels anyway. Please don't say because all the 2F2F kiddies are doing it. They are also slotting and drilling which provides no benefit to a real world car. Just for looks. Spend the money on really good pads. And stainless steel lines(they don't expand as much) Brembo drilled rotors "IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if any products are used on the track they are not warrantable."
