fatboy Posted November 20, 2007 Report Share Posted November 20, 2007 ok this subject has probably been covered in another thread but i'll probably be spending hours tryin to trace it down.... just wanting to know where i need to place my jack if i get a flat or for whatever other reason. if i get a flat on one of my rear wheels i assume just place it under the axle shaft nearest the flat tire. but what about a flat on a front tire? Link to comment Share on other sites More sharing options...
ShelbyPilot Posted November 20, 2007 Report Share Posted November 20, 2007 There are jacking points on the sides of the car. Behind the front tire and in front of the rear tire. They are in the same area as most cars. However, a standard jack will not fit under the car without being on blocks. You should be able to find a diagram in your manual. Link to comment Share on other sites More sharing options...
fatboy Posted November 20, 2007 Author Report Share Posted November 20, 2007 There are jacking points on the sides of the car. Behind the front tire and in front of the rear tire. They are in the same area as most cars. However, a standard jack will not fit under the car without being on blocks. You should be able to find a diagram in your manual. yea i'm goin to get a low profile jack for the SGT Link to comment Share on other sites More sharing options...
fatboy Posted November 20, 2007 Author Report Share Posted November 20, 2007 There are jacking points on the sides of the car. Behind the front tire and in front of the rear tire. They are in the same area as most cars. However, a standard jack will not fit under the car without being on blocks. You should be able to find a diagram in your manual. the owners manual is pretty vague...just says there are jackpoints in front of rear wheel and behind front wheel but i cant see a place to put them...all looks like thin sheet metal i miss my truck i guess my retarded butt needs someone to come over and stick some bullseyes under my car so i know where. Link to comment Share on other sites More sharing options...
Lurker Too Posted November 20, 2007 Report Share Posted November 20, 2007 the owners manual is pretty vague...just says there are jackpoints in front of rear wheel and behind front wheel but i cant see a place to put them...all looks like thin sheet metal i miss my truck i guess my retarded butt needs someone to come over and stick some bullseyes under my car so i know where. then trade your Shelby in for a new truck Link to comment Share on other sites More sharing options...
fatboy Posted November 21, 2007 Author Report Share Posted November 21, 2007 then trade your Shelby in for a new truck no :do what: Link to comment Share on other sites More sharing options...
Alloy Dave Posted November 21, 2007 Report Share Posted November 21, 2007 ok this subject has probably been covered in another thread but i'll probably be spending hours tryin to trace it down.... just wanting to know where i need to place my jack if i get a flat or for whatever other reason. if i get a flat on one of my rear wheels i assume just place it under the axle shaft nearest the flat tire. but what about a flat on a front tire? There is some documentation stating that you should NOT jack under the rear axle. However, if I were to do it anyway, I certainly would not tell anyone here....for fear of getting flamed. There are many things on the forum that you can be flamed for...learn them... 1) speaking highly about import cars 2) not using the exact viscosity oil recommended by Ford 3) trusting anything done by Consumer Reports 4) owning a Chevy Guess who has done all of the above... Link to comment Share on other sites More sharing options...
ShelbyPilot Posted November 21, 2007 Report Share Posted November 21, 2007 Look under the sides of your car. You should see a thin ridge that runs most of the length between the wheels. A bout foot behind the front wheel and a foot in front of the rear wheel there is about a 2" area that is marked by two curves in the ridge. Those are the jack points. Link to comment Share on other sites More sharing options...
fatboy Posted November 21, 2007 Author Report Share Posted November 21, 2007 Look under the sides of your car. You should see a thin ridge that runs most of the length between the wheels. A bout foot behind the front wheel and a foot in front of the rear wheel there is about a 2" area that is marked by two curves in the ridge. Those are the jack points. ok i see them...i was lookin further under the car so...now i need a jack low enough to get under where the ridges are it looks like this kind of jack will fit under the SGT...or am i wrong? http://youtube.com/watch?v=hDjbz5TrHJA&feature=related Link to comment Share on other sites More sharing options...
1RedSnake Posted November 21, 2007 Report Share Posted November 21, 2007 This has been discussed in previous threads. Try the link below for a page from the pre-delivery manual showing lift points on the mustang. www.stangsunleashed.com/forums/index.php?showtopic=8852&hl=lifting Post this link in your browser and scroll down to where 5.4 Shelby listed "LIFT POINTS". Link to comment Share on other sites More sharing options...
fatboy Posted November 21, 2007 Author Report Share Posted November 21, 2007 guess what i came across? this guy deserves a Darwin award http://www.funnyhub.com/pictures/img/low-tech-car-jack.jpg Link to comment Share on other sites More sharing options...
Pastor Passum Posted November 21, 2007 Report Share Posted November 21, 2007 guess what i came across?this guy deserves a Darwin award http://www.funnyhub.com/pictures/img/low-tech-car-jack.jpg Hurts just to look at that Link to comment Share on other sites More sharing options...
stump_breaker2 Posted November 22, 2007 Report Share Posted November 22, 2007 guess what i came across?this guy deserves a Darwin award http://www.funnyhub.com/pictures/img/low-tech-car-jack.jpg What's wrong with it? He has primary and secondary bracing.... :do what: Geeez, you just can't please some people! Link to comment Share on other sites More sharing options...
Son of GT Posted November 22, 2007 Report Share Posted November 22, 2007 I have a lo-pro floor jack and it's still too tall to fit under any part my SGT. So I cut and assembled a set of three planks in graduated steps in order to get the car high enough off the ground to get the jack under a proper lift point on the car. Link to comment Share on other sites More sharing options...
Grabber Posted November 22, 2007 Report Share Posted November 22, 2007 See page 2 of this Ford document. http://home.comcast.net/~kjobrien/Vehicle_...s__S7Z06A12.pdf Link to comment Share on other sites More sharing options...
Grabber Posted November 29, 2007 Report Share Posted November 29, 2007 See page 2 of this Ford document. http://home.comcast.net/~kjobrien/Vehicle_...s__S7Z06A12.pdf Bump for Flaw1 Link to comment Share on other sites More sharing options...
ilmor Posted November 29, 2007 Report Share Posted November 29, 2007 I assume that you bought a jack and spare for your car in case of a flat...since, SGT's do not come w/ them. Link to comment Share on other sites More sharing options...
fllaw1 Posted November 29, 2007 Report Share Posted November 29, 2007 Bump for Flaw1 Thanks... Grabber Link to comment Share on other sites More sharing options...
fllaw1 Posted November 29, 2007 Report Share Posted November 29, 2007 I assume that you bought a jack and spare for your car in case of a flat...since, SGT's do not come w/ them. AHHH...The Things the dealer doesn't tell us Link to comment Share on other sites More sharing options...
DDT Posted November 29, 2007 Report Share Posted November 29, 2007 I assume that you bought a jack and spare for your car in case of a flat...since, SGT's do not come w/ them. Shelby GTs don't come with a jack and spare tire????????????????? What the H did they do with the ones that came in the cars when they started out as Mustang GTs???????????????? Link to comment Share on other sites More sharing options...
ShelbyPilot Posted November 29, 2007 Report Share Posted November 29, 2007 Shelby GTs don't come with a jack and spare tire?????????????????What the H did they do with the ones that came in the cars when they started out as Mustang GTs???????????????? They never had them to begin with. They left Flat Rock with that air compressor thing. Link to comment Share on other sites More sharing options...
DDT Posted November 29, 2007 Report Share Posted November 29, 2007 They never had them to begin with. They left Flat Rock with that air compressor thing. Did they change the rim and tire size on the Shelby GT???????? Link to comment Share on other sites More sharing options...
ilmor Posted November 29, 2007 Report Share Posted November 29, 2007 Did they change the rim and tire size on the Shelby GT???????? I believe that Ford sends the former "Mustang GT" to Shelby in Vegas with the 18" Bullits already installed...so, they are not "changed". I think this is what youre asking? Link to comment Share on other sites More sharing options...
fatboy Posted November 30, 2007 Author Report Share Posted November 30, 2007 I assume that you bought a jack and spare for your car in case of a flat...since, SGT's do not come w/ them. i bought a full size spare....no jack yet...want to know what jack to use. anything besides floor jacks? (i like to use Ford factory jack) i guess i need to stack some 2x10s?...i know when u have a flat its goin to make the car sit even lower. i guess i need about another 4 to 6 inches of wood ramping. damn my trunk space is gettin crowded. Since we dont have lockers at work i have to keep my filthy work boots in a box in my trunk and wear sneakers while driving to work so i wont ruin the carpeting. anoying as <_< Link to comment Share on other sites More sharing options...
nrsnrs Posted December 17, 2007 Report Share Posted December 17, 2007 ok this subject has probably been covered in another thread but i'll probably be spending hours tryin to trace it down.... just wanting to know where i need to place my jack if i get a flat or for whatever other reason. if i get a flat on one of my rear wheels i assume just place it under the axle shaft nearest the flat tire. but what about a flat on a front tire? Go to the Ford Dealer and ask them to show you where they put the pads to lift the car. The pinch welds are useless for jacking. They showed me where to put a jack to lift the car front & rear. Link to comment Share on other sites More sharing options...
