MoTheDigitalDiva Posted November 10, 2007 Report Share Posted November 10, 2007 lost my post from yesterday, thought i'd try again... i was wondering if anyone can explain the difference in performance between a 5 and 6 speed. and is it possible to upgrade my sgt to a 6 speed - would i want to??? Link to comment Share on other sites More sharing options...
SGT2666 Posted November 10, 2007 Report Share Posted November 10, 2007 lost my post from yesterday, thought i'd try again... i was wondering if anyone can explain the difference in performance between a 5 and 6 speed. and is it possible to upgrade my sgt to a 6 speed - would i want to??? Generally I think the 6 speed is used to narrow the gap between gears making it easier to stay in the sweet spot of the powerband(less RPM loss between gears). They can also give you a wider spread between 1st gear and high gear giving the great gear to get out of the hole and still a reasonable cruising gear. Probably more to it then that I'm sure someone around here knows Link to comment Share on other sites More sharing options...
07SHELBY GT Posted November 10, 2007 Report Share Posted November 10, 2007 Best I can tell you is the Tremec that is used in most vehicles,GT500,GTO,Vette,Viper etc has double overdrive for some serious top end action!Don't have ratios handy for either trans.With the 6 speed you could run a 4:10 rear and still do some top end banzai runs.Would actually be better to use a 2:43 rear gear and get a 6 speed with 4 reduction gears,5th would be direct and 6 only as overdrive to keep driveline speed and vibration down.That is the type of set-up used on a lot of german road rockets.I know that the 6 speed in the Vette also yields LOW highway cruising RPM for about 30+ MPG on the highway,Thanks to double overdrive. Link to comment Share on other sites More sharing options...
Alloy Dave Posted November 11, 2007 Report Share Posted November 11, 2007 Generally I think the 6 speed is used to narrow the gap between gears making it easier to stay in the sweet spot of the powerband(less RPM loss between gears). They can also give you a wider spread between 1st gear and high gear giving the great gear to get out of the hole and still a reasonable cruising gear. Probably more to it then that I'm sure someone around here knows I don't believe this is true. Remember that 4th gear in both transmissions is 1:1...so there are the same number of gears in each trans in the range where one would be racing. The difference is that the 6-speed has TWO overdrive gears. There are two advantages to this. 1) Better fuel economy on the highway due to the 2nd OD gear. 2) The ability to change to a taller differential ratio while still maintaining decent highway drivability. AD Link to comment Share on other sites More sharing options...
