Cutch Adjustment
dqron
What's a cutch? :doh:
Seriously, I am pretty sure that it's a hydraulic clutch and no adjustment is available.
Mine is the same way. Worse yet I have 5 manual transmission cars and this is the only one I constantly kill trying to ease it out of the hole. I kill it at least twice every time I drive it. I never did this with my '06 GT.
My 68 Z28 that barely idles, has zero low end torque, an M21 with 2.2:1 1st gear and 3.73 rear gears is easier to get moving than this thing. Of course I know with it that I have to run 1500 RPM just to let out the clutch or it will die too.
Another '69Z owner. Nice.
I have a '69. Mine is not a real Z. It was originally an SS with a 396, but when I bought it the engine was out. I put a DZ302 in it. Here are a few pics BEFORE it went in the body shop last year. I'll make it official by saying I HATE the graphics on the car....I'm having it put back to red with black stripes. And no, there will not be a single Z28 emblem on it...as it's not a real Z. I do plan to put 302 emblems on the hood and fenders though.
The twin disc cera-metalic clutch on the GT500 is pretty unforgiving. My friction point is closer to the floor however but it took a while to get use to easing it into 1st gear consistently and w/o killing the engine.
I actually drove it to the local Ford dealer today to order some parts and never killed it once!!!
Yes, this clutch has a different feel than anything I think I've ever driven before. I almost ordered one like it for my 69 but decided not to, of course that one would not have been hydraulic.
Here ya go Alloy Dave, the only pics I have right now:
It's every bit as clean or cleaner than it looks. I got it from a GM corporate Exec. in Detroit. The only problem is the clock doesn't work in the Tic-Toc-Tach, but this winter the dash comes apart and it goes to get the clock rebuilt.
csx4350: That is one sweet Z28! Thanks for posting.
DC
I took it up to Ford for an anti freeze leak and asked about the clutch. They confirmed what you all have said "No Adjustments" on a hydraulic clutch. I guess as you wear down the clutch it goes closer to the floor.
Even says so in your owner's manual:
Your vehicle is equipped with a twin disc cera-metallic clutch. This
clutch incorporates racing technology to combine a low inertia clutch
assembly with a very durable friction material with high torque
capability. Depending on your driving technique, the smoothness of how
the vehicle reacts to clutch engagement may be different from other
vehicles you have driven. This behavior is typical of a cera-metallic
clutch and is not indicative of any abnormal issues with your vehicle.
Wow...nice! Is the 302 stock inside? Mine is except for roller rockers. The sound of the cam is one of the most precious sounds I know. Here is a pic of mine the last time I saw it...about 6 weeks ago.
AD
Sorry to break up this little bowtie moment, but :backtotopic:
I actually like the clutch engagement being so high. All you have to do is just barely touch the pedal to grab the next gear. If you're really quick with it, the clutch "chirps"; or maybe it's just a really compressed hisssss. Either way it saves some time on the shift.
As for the standing start, you'll get used to it. I do have to remind myself that the Mini Cooper clutch action is way different.....and so is the acceleration...and the braking...... :backtotopic::ohsnap:
I actually am getting used to it, I haven't killed it since my original reply a week ago. Of course I just screwed up by saying that.
Yes Dave, it is all original in the engine except that it has forged TRW 10.3:1 pistons instead of the original 11:1's to help run on the crap fuel these days. The 30/30 cam sounds great, the lope doesn't smooth out until about 3000RPM.
  • 1 month later...
Yep, this clutch definitely has a unique feel to it. Once I got used to it, I'm having a hard time with my '05 Mustang GT clutch.... not to mention the 5-speed in my '87 "20th Anniversary" Z28 convertible. Not a '69 but a rare Camaro at that!! I've also noticed that as I release the clutch while the tranny is in gear, it makes a hissing sound. The dealership tells me that's normal. I just don't know what it is I'm hearing. The noise is barely heard when the tranny is in neutral. Now, if I hold the clutch pedal while it's hissing and I turn the ignition off, the hissing stops. Are you guys experiencing the same hiss? Maybe it's the snake under the hood :snake:
Willie
2008 GT500
Willie
2008 GT500
Willie, read your owner's manual and you will find the answers.
Dave
Willie
2008 GT500
This is normal, every GT500 has it - and there are lots of posts with regards to this subject.
Can anyone compare the GT500 clutch to a stock 03 Cobra or Ford GT (not the Mustang) clutch?
My 03 Cobra clutch was WAY stiffer, to the point my wife couldnt drive it. (thats bad?).
The engagement point was more in the center and smoother as opposed to my GT500 .
My 03 had an aftermarket adjuster/quadrant which helped. Hope this helps, Mike
If you think the '03 Cobra clutch is easy to drive, the GT500 clutch is a piece of cake. I also had an '03 Cobra and in 2-1/2 years of ownership, my wife drove it ZERO times. And I did not have an aftermarket adjuster. My wife's issue was the clutch and the Tri-Ax shifter.....
Willie
Willie
what's a clutch? :hysterical2:
I just stick the gear shifter in whatever gear I think I will need, and eventually the grinding stops. :waiting:
good news is the hissing sound has stopped since I started using this technique! :hysterical:
Willie
Tha aftermarket adjuster only helped, the clutch was too stiff for her. By the way, I really liked my Tri-Ax shifter. Mike
