Mustang5 Posted October 21, 2007 Report Share Posted October 21, 2007 Ok guys, it is finally coming together. I have been whining about the dreaded engine tick for 5 months now. I am finally seeing some pain amongst the rest of you. My tick showed up on the driver side of the engine at 1200 miles and got worse with time. At 3000 miles Ford agreed to replace all of my valve lash adjusters (lifters). When I picked the car up the original tick had been fixed, but I now had a new and slightly different tick. The new tick is on the passenger side of the car and lower in the block as many of you have described. The difference with the new tick is that it has not changed with the addition of 2000 more miles. On a previous post titled engine tick revisited, Kirkm posted an audio/video of his car and his engine tick. My new tick is the same exact one that Kirkm has. I think we need to run some type of survey among our members or at least have everyone who reads this post respond with yes I have the same tick or no I don't, and see what percentage of us have the same tick that Kirkm and I have. Is this noise normal as several Ford dealers have told some of you or is a valve lash adjuster problem just now surfacing? Personally I am embarassed by the noise and it detracts greatly from an otherwise awesome car. Link to comment Share on other sites More sharing options...
LuckySnake Posted October 21, 2007 Report Share Posted October 21, 2007 Ok guys, it is finally coming together. I have been whining about the dreaded engine tick for 5 months now. I am finally seeing some pain amongst the rest of you. My tick showed up on the driver side of the engine at 1200 miles and got worse with time. At 3000 miles Ford agreed to replace all of my valve lash adjusters (lifters). When I picked the car up the original tick had been fixed, but I now had a new and slightly different tick. The new tick is on the passenger side of the car and lower in the block as many of you have described. The difference with the new tick is that it has not changed with the addition of 2000 more miles. On a previous post titled engine tick revisited, Kirkm posted an audio/video of his car and his engine tick. My new tick is the same exact one that Kirkm has. I think we need to run some type of survey among our members or at least have everyone who reads this post respond with yes I have the same tick or no I don't, and see what percentage of us have the same tick that Kirkm and I have. Is this noise normal as several Ford dealers have told some of you or is a valve lash adjuster problem just now surfacing? Personally I am embarassed by the noise and it detracts greatly from an otherwise awesome car. Silly question, did you get a receipt for the new lifters? Link to comment Share on other sites More sharing options...
Dropping__Chronic Posted October 21, 2007 Report Share Posted October 21, 2007 They are used to saying it's normal as they have had a lot of practice. 1999 Cobra 2001 Cobra 2003 Cobra 2004 Cobra I figured they would start advertising it as a feature to nip it in the bud. Sorry for your trouble, but I'm baffled why this problem seems to plague the Cobra year after year. Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 Silly question, did you get a receipt for the new lifters? Yes I do. I'm going to meet with my local Ford Field Engineer at my convenience. I hope to get some ammo from you guys before I make the appointment. So starting with the two of you that have already commented, will you please respond whether you have the dreaded tick or not so we can start working up some percentages. Thanks, Rob Link to comment Share on other sites More sharing options...
Snoopy Posted October 22, 2007 Report Share Posted October 22, 2007 10,000 miles, no ticky. Link to comment Share on other sites More sharing options...
ColdwaterHotrod Posted October 22, 2007 Report Share Posted October 22, 2007 See if you can have another member be there with his car when the Ford Engineer comes so you can say listen to this one that has the "tick" & this one that doesn't. Link to comment Share on other sites More sharing options...
Grabber Posted October 22, 2007 Report Share Posted October 22, 2007 3300 miles and no tick, just a bad clutch. Link to comment Share on other sites More sharing options...
Justin00Stang Posted October 22, 2007 Report Share Posted October 22, 2007 does it occur at a specific RPM? Link to comment Share on other sites More sharing options...
Snoopy Posted October 22, 2007 Report Share Posted October 22, 2007 does it occur at a specific RPM? The ones I have heard, it is at idle. Link to comment Share on other sites More sharing options...
rpretzel Posted October 22, 2007 Report Share Posted October 22, 2007 3300 miles and no tick, just a bad clutch. +1 Link to comment Share on other sites More sharing options...
LuckySnake Posted October 22, 2007 Report Share Posted October 22, 2007 Yes I do. I'm going to meet with my local Ford Field Engineer at my convenience. I hope to get some ammo from you guys before I make the appointment. So starting with the two of you that have already commented, will you please respond whether you have the dreaded tick or not so we can start working up some percentages. Thanks, Rob Mine has zero ticking, although it did it one time on start up for about 10 seconds until I shut her off. I have personally listened to several GT500's and none of them were ticking. The changing of your ticking from one part of the engine to another doesn't make any sense to me, unless you got another bad lifter in the second batch? My oil pressure indicator needle is normally 3/4 the way up, is yours this way too? Man, I'd rather change a bad clutch. I'm sure glad your car is under warranty and hope Ford gets this fixed soon. Please let us know how you get this resolved. Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 Mine has zero ticking, although it did it one time on start up for about 10 seconds until I shut her off. I have personally listened to several GT500's and none of them were ticking. The changing of your ticking from one part of the engine to another doesn't make any sense to me, unless you got another bad lifter in the second batch? My oil pressure indicator needle is normally 3/4 the way up, is yours this way too? Man, I'd rather change a bad clutch. I'm sure glad your car is under warranty and hope Ford gets this fixed soon. Please let us know how you get this resolved. That's exactly what I think happened. They changed out all the lifters and put a marginal one like a bunch of us have back in on the other bank. Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 does it occur at a specific RPM? The tick is heard primarily at idle. If I bring the rpm up off idle to say 1100 or 1200 rpm I can hear the rythem of the tick pick up with engine speed. I never hear it any other time. It's alway after the car has been driven at least 10-15 miles or more, or after doing losts of stop and go type driving like around town when your in and out of stores. Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 10,000 miles, no ticky. Thanks Snoopy Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 See if you can have another member be there with his car when the Ford Engineer comes so you can say listen to this one that has the "tick" & this one that doesn't. That's a good idea, I have listened to 3 cars locally that do not tick. Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 That's exactly what I think happened. They changed out all the lifters and put a marginal one like a bunch of us have back in on the other bank. By the way one of the things Ford did to trouble shoot was to check the oil pressure in the engine. From the way they described it they were able to get measurements in several locations to include the head. All was normal! Link to comment Share on other sites More sharing options...
Mustang5 Posted October 22, 2007 Author Report Share Posted October 22, 2007 3300 miles and no tick, just a bad clutch. That's to bad Grabber. Hopefully the new one will go about 60K further Link to comment Share on other sites More sharing options...
svtkeith Posted October 22, 2007 Report Share Posted October 22, 2007 3300 miles and no tick, just a bad clutch. Hey GRAB, I didn't know you had probs with your clutch.... that sux. Did you have to have it replaced or just fixed ? Link to comment Share on other sites More sharing options...
mobeydick Posted October 22, 2007 Report Share Posted October 22, 2007 7,500 miles and mine doesn't tick. How did you break yours in? I let it all hang out from the get go. Link to comment Share on other sites More sharing options...
Snoopy Posted October 22, 2007 Report Share Posted October 22, 2007 7,500 miles and mine doesn't tick. How did you break yours in? I let it all hang out from the get go. Me too, to a point. Link to comment Share on other sites More sharing options...
Lutzcat Posted October 22, 2007 Report Share Posted October 22, 2007 7,500 miles and mine doesn't tick. How did you break yours in? I let it all hang out from the get go. I've got 9400 on mine, I'm half deaf, but not heard any ticks. Yall have me paranoid now. Once a week I put my ear to each fender and on the hood vents, can only hear the belt whine. My family thinks I'm crazy, they think I'm talking to my car. I haven't told them yet, but my baby is talking. Scott Link to comment Share on other sites More sharing options...
mach1fever Posted October 22, 2007 Report Share Posted October 22, 2007 I've got 9400 on mine, I'm half deaf, but not heard any ticks. Yall have me paranoid now. Once a week I put my ear to each fender and on the hood vents, can only hear the belt whine. My family thinks I'm crazy, they think I'm talking to my car. I haven't told them yet, but my baby is talking. Scott Scott, If its any consolation. When I was in your car in Orlando I did not hear a tick. Roger Link to comment Share on other sites More sharing options...
Rarecat Posted October 22, 2007 Report Share Posted October 22, 2007 I don't think mine has the "tick" but I'm not sure. At idle you can hear what I think is the injectors firing, which sounds like ticking, rev the motor and all you hear is SC whine...... It does sound less than threatening and kinda crappy when showing it off while parked....not like the lopey rumble I'd rather hear Link to comment Share on other sites More sharing options...
regalt87 Posted October 22, 2007 Report Share Posted October 22, 2007 At about 500 to 700 miles or around that I was in a drive through and noticed the tick. Only did it one other time and now I have 3000 miles and have not noticed it again?? Link to comment Share on other sites More sharing options...
Vogon Posted October 22, 2007 Report Share Posted October 22, 2007 I've got 9400 on mine, I'm half deaf, but not heard any ticks. Yall have me paranoid now. Once a week I put my ear to each fender and on the hood vents, can only hear the belt whine. My family thinks I'm crazy, they think I'm talking to my car. I haven't told them yet, but my baby is talking. Scott You're the Car Whisperer... I have 8,800 miles on mine (Build date 6/22/06), and no ticks. I'm guessing they rules out exhaust leak at the manifold, with the metal expansion when hot? The right side may have been masked by the louder left side, and once fixed, the right side becomes noticable. Just thinking out loud... Link to comment Share on other sites More sharing options...
Alloy Dave Posted October 22, 2007 Report Share Posted October 22, 2007 10,000 miles, no ticky. He's not talking about your Mini. I have 4,200 miles and I've heard the tick rarely, but intermittently ever since about 500 miles were on the odo. My most recent "sighting" was about 2 weeks ago. The next day...gone. Dave Link to comment Share on other sites More sharing options...
Rarecat Posted October 22, 2007 Report Share Posted October 22, 2007 After viewing/listening to the clips on the other thread, I don't have the "tick" (insert heavy sigh of relief here). The way it sounds and the intermittent nature of it reminds me of the old "lazy lifter" problem from back in the push rod days... I sure hope there is a logical and satisfactory solution forthcoming from our friends at Ford Link to comment Share on other sites More sharing options...
CobraCrazy Posted October 22, 2007 Report Share Posted October 22, 2007 6600 miles and no tick (no clutch problem yet either-knock on wood) CC Link to comment Share on other sites More sharing options...
sandyman Posted October 22, 2007 Report Share Posted October 22, 2007 June 06 build. 2000 miles and no tick and no problems. Link to comment Share on other sites More sharing options...
whazen1 Posted October 22, 2007 Report Share Posted October 22, 2007 I drove mine on Saturday for the first time in 3 weeks. I was listening for a tick but instead heard a knock from the rear. Almost like something was moving back and forth in the trunk. Hopefully I will track it down this weekend. I am hoping it is the exhaust pipe or something easy. Link to comment Share on other sites More sharing options...
