My GT500 1st Stop will the drag strip
Wondering if any one eles will take there car from the dealer to the strip. HOPEFULY i get my car on a weekday so i can go to test and tune that same week. Would love to run some high 11's frist couple week there out. My GT500 will see many many 1/4 mile passes :shift:
Mine will probably hit the dyno before the strip. I want to seat the rings and get used to the shifter/trans/clutch and the wireless throttle, (and change the oil) before knocking out a few 1/4 mile passes.
But like you, I can't wait to take it to the strip!!!
Like Jetsolver, I am a big believer that the fluids need changing early. I change mine at 50, 500, 1500 miles before falling into a normal interval. And the engine needs to be run hard early to seal it up, with coast downs to clean it out. Ring seal is everything! Generally, a good break-in shows up on the dyno and lives longer.
Don't drive it like you hate it, but don't follow the manual either.
A thread on break-in procedures is probably a good idea.
I will break-in/seat rings and a couple of oil changes 1st.
Would like to have the car dynod stock, then run it.
A rear tire change is a must for sure to anyone taking thr GT500 to the strip.
Then go with a cat back system, and possibly a CAI, tune, and dyno.
Then back to the track.
11sec. in the 1/4 is my goal, which should be easy.
100% fluid changes at about 500 miles then on it. I drove the 97 quite hard in the early days and it has rewarded me well.
SORRY MADE MISTAKE[1500] TO 500 MILES NOTCIE CHANGE IN POST.ABOUT THE FLUID'S WHEN SHOULD I CHANGE MY OIL ,FLUID'S FOR THE 2007 GT500?. IN MY CURRENT 93 L.X I USE FULL SYNTHETIC OIL RECOMENDED BY MY MECHANIC [DASIVARACING] I CHANGE RUGHLY EVERY 2500 KM[FROM CANADA] ALSO I THINK THAT I READ SOMEWHERE THAT THE 2007 SHELBYGT500 IS FORD RECOMENDED FULL SYNTHTIC OIL FOR IT AND PREIMIUME GAS FOR THE S/C.TO ME MAKE'S SENCE BECAUSE ALSO MY MECANIC ADVISED WHEN AFTER INSTALLING MY S/C TO USE ONLY SUNOCO 94!.BEST OF LUCK TO ALL!!! :party: :bandance: :happy feet:
Ditto.
I'll run it for a few miles, baseline dyno and then beat the everloving crap out of it at the track :happy feet:
Good idea. High performance cars benifit from all sorts of things, for example brake bedding in etc. We will hear lots of different opinions but some synthesis is possible. Hopefully Ford will do something like the SVT hotline, from which I got lots of careing, thoughtful advice. They even sent the original spring rates and specs to Eibac so I could match the chassis tuning as close to factory while lowering the car!
alot of guys were having problems with the terms trying to beat on it out of the box. The factory now runs engines to seat the seals properly. Take it easy on it for the first 500 and change the fluids then romp on it. BTW if your looking for numbers on your shelby they will very a lot with mileage. 5-10k is the sweet spot.
