mosconiac Posted September 13, 2007 Report Share Posted September 13, 2007 What did you guys tether the PS & washer fluid caps to? did you guys remove the original PS cap? Did you just chop it off or is the tether "pin" removable from the top of the reservoir? TIA EDIT: I found my answer on the PS reservoir. The original tether can be pulled off the pin and the new tether simply slips over the same pin. Still don't know what to tether the washer fluid to though. There's a couple of fasteners on radiator support that could be used but... Link to comment Share on other sites More sharing options...
Alloy Dave Posted September 13, 2007 Report Share Posted September 13, 2007 What did you guys tether the PS & washer fluid caps to? did you guys remove the original PS cap? Did you just chop it off or is the tether "pin" removable from the top of the reservoir? TIA EDIT: I found my answer on the PS reservoir. The original tether can be pulled off the pin and the new tether simply slips over the same pin. Still don't know what to tether the washer fluid to though. There's a couple of fasteners on radiator support that could be used but... Put it around the neck of the reservoir fill tube. Link to comment Share on other sites More sharing options...
