Help! Need factory stripes!!
EXPcustom
So four days after I bought my GT500 I am on 101 South in Sunnyvale a piece of debris comes flying at me from the side and hits my roof and the side of my car I could not avoid it as it came from the side, never saw anything like it before...
So long story short it gashes my top stripe and the one on the side of my car only sctratches the clear coat under so I was lucky there...
I call the Ford dealer and after a half an hour they tell me I can only get the Ford Racing stripes not the GT500 stripes after I tell him I just bought the car from them and am not some kid looking to do a conversion.
I do not want aftermarket stripes I heard the letters on the side are not quiet right plus my stripes are satin silver so I know it will be an impossible color match.
So is there a part number or a way I can get factory stripes anyone? Help, I have paperwork and pics I own a GT500 not looking to do some half ass conversion
Grabber is correct. ANY Ford parts department can order these.
I don't think you have to order the entire set. You should be able to just order the pieces for the roof. I know you can order just the side stripe alone.
If I remember I "think" the side stripe was around $85. I think that is for each side.
Not sure what just the roof stripes will run and I think if you can order just the roof stripes those may only come as a set of two for each side.
If your dealer's parts department is to dumb to figure it out call another dealer. They will probably need your vin number to look it up
The entire stripe kit for the entire car is around $1425. I saw one on E-bay.
I think it is just over $1250 through parts.
They are expensive, but if you can buy just the sections you need then it shouldn't be bad. Sounds like he would only need the one side stripe and just the roof stripes.
They all come pre-cut in sections, so I'm pretty sure you can order just the sections you need without having to buy the entire kit.
I can't recall where I saw it, but somewhere on this site I remember seeing a PDF file that had the stripes exploded off the car with individual part numbers for each stripe. That would lead me to believe you can order each stripe section individually.
HSURB
You can buy the pieces separately. The sides are about $85.00. Before I bought my car I looked at a stripe delete car that was a good deal and I was going to paint the stripes on and just sticker the sides. The parts department said they would be able to get them separately.
Maybe this will help you.
And here is the part number for each color choice
<20000 A Kit - Stripe Decal
7R3Z-6320000-AA Accent Stripe - Satin Silver (CJPAB0) RH Door Lower
7R3Z-6320000-AB Accent Stripe - Perform White (CJPAC0) RH Door Lower
7R3Z-6320000-AC Accent Stripe - Vista Blue (CJPAY0) RH Door Lower
7R3Z-6320000-AD Accent Stripe - Tungsten (CJPAZ0) RH Door Lower
7R3Z-6320001-AA Accent Stripe - Satin Silver (CJPAB0) LH Door Lower
7R3Z-6320001-AB Accent Stripe - Perform White (CJPAC0) LH Door Lower
7R3Z-6320001-AC Accent Stripe - Vista Blue (CJPAY0) LH Door Lower
7R3Z-6320001-AD Accent Stripe - Tungsten (CJPAZ0) LH Door Lower
<20000 B Kit - Stripe Decal
7R3Z-6320000-BA Accent Stripe - Satin Silver (CJPAB0) LowerRH/LH Located In Bumper Cover
7R3Z-6320000-BB Accent Stripe - Perform White (CJPAC0) LowerRH/LH Located In Bumper Cover
7R3Z-6320000-BC Accent Stripe - Vista Blue (CJPAY0) LowerRH/LH Located In Bumper Cover
7R3Z-6320000-BD Accent Stripe - Tungsten (CJPAZ0) LowerRH/LH Located In Bumper Cover
<20000 C Kit - Stripe Decal
7R3Z-6320000-CA Accent Stripe - Satin Silver (CJPAB0) Center RH/LH Located In Bumper Cover
7R3Z-6320000-CB Accent Stripe - Perform White (CJPAC0) CenterRH/LH Located In Bumper Cover
7R3Z-6320000-CC Accent Stripe - Vista Blue (CJPAY0) CenterRH/LH Located In Bumper Cover
7R3Z-6320000-CD Accent Stripe - Tungsten (CJPAZ0) CenterRH/LH Located In Bumper Cover
<20000 D Kit - Stripe Decal
7R3Z-6320000-DA Accent Stripe - Satin Silver (CJPAB0) RH Upper Located In Bumper Cover
7R3Z-6320000-DB Accent Stripe - Perform White (CJPAC0) RH Upper Located In Bumper Cover
7R3Z-6320000-DC Accent Stripe - Vista Blue (CJPAY0) RH Upper Located In Bumper Cover
7R3Z-6320000-DD Accent Stripe - Tungsten (CJPAZ0) RH Upper Located In Bumper Cover
7R3Z-6320001-DA Accent Stripe - Satin Silver (CJPAB0) Upper LH Located In Bumper Cover
7R3Z-6320001-DB Accent Stripe - Perform White (CJPAC0) Upper LH Located In Bumper Cover
7R3Z-6320001-DC Accent Stripe - Vista Blue (CJPAY0) Upper LH Located In Bumper Cover
7R3Z-6320001-DD Accent Stripe - Tungsten (CJPAZ0) Upper LH Located In Bumper Cover
<20000 E Kit - Stripe Decal
7R3Z-6320000-EA Accent Stripe - Satin Silver (CJPAB0) RH Mounted On Hood
7R3Z-6320000-EB Accent Stripe - Perform White (CJPAC0) RHMounted On Hood
7R3Z-6320000-EC Accent Stripe - Vista Blue (CJPAY0) RH Mounted On Hood
7R3Z-6320000-ED Accent Stripe - Tungsten (CJPAZ0) RH Mounted On Hood
7R3Z-6320001-EA Accent Stripe - Satin Silver (CJPAB0) LH Mounted On Hood
7R3Z-6320001-EB Accent Stripe - Perform White (CJPAC0) LH Mounted On Hood
7R3Z-6320001-EC Accent Stripe - Vista Blue (CJPAY0) LH Mounted On Hood
7R3Z-6320001-ED Accent Stripe - Tungsten (CJPAZ0) LH Mounted On Hood
<20000 F Kit - Stripe Decal
7R3Z-6320000-FA Accent Stripe - Satin Silver (CJPAB0) RH Roof
7R3Z-6320000-FB Accent Stripe - Perform White (CJPAC0) RH Roof
7R3Z-6320000-FC Accent Stripe - Vista Blue (CJPAY0) RH Roof
7R3Z-6320000-FD Accent Stripe - Tungsten (CJPAZ0) RH Roof
7R3Z-6320001-FA Accent Stripe - Satin Silver (CJPAB0) LH Roof
7R3Z-6320001-FB Accent Stripe - Perform White (CJPAC0) LH Roof
7R3Z-6320001-FC Accent Stripe - Vista Blue (CJPAY0) LH Roof
7R3Z-6320001-FD Accent Stripe - Tungsten (CJPAZ0) LH Roof
<20000 G Kit - Stripe Decal
7R3Z-6320000-GA Accent Stripe - Satin Silver (CJPAB0) RH/LH Decklid
7R3Z-6320000-GB Accent Stripe - Perform White (CJPAC0) RH/LH Decklid
7R3Z-6320000-GC Accent Stripe - Vista Blue (CJPAY0) RH/LH Decklid
7R3Z-6320000-GD Accent Stripe - Tungsten (CJPAZ0) RH/LH Decklid
<20000 H Kit - Stripe Decal
7R3Z-6320000-HA Accent Stripe - Satin Silver (CJPAB0) Upper Mounts In Spoiler RH/LH
7R3Z-6320000-HB Accent Stripe - Perform White (CJPAC0) Upper Mounts In Spoiler RH/LH
7R3Z-6320000-HC Accent Stripe - Vista Blue (CJPAY0) Upper Mounts In Spoiler RH/LH
7R3Z-6320000-HD Accent Stripe - Tungsten (CJPAZ0) Upper Mounts In Spoiler RH/LH
<20000 J Kit - Stripe Decal
7R3Z-6320000-JA Accent Stripe - Satin Silver (CJPAB0) Lower Mounts In Spoiler RH/LH
7R3Z-6320000-JB Accent Stripe - Perform White (CJPAC0) Lower Mounts In Spoiler RH/LH
7R3Z-6320000-JC Accent Stripe - Vista Blue (CJPAY0) Lower Mounts In Spoiler RH/LH
7R3Z-6320000-JD Accent Stripe - Tungsten (CJPAZ0) Lower Mounts In Spoiler RH/LH
<20000 K Kit - Stripe Decal
7R3Z-6320000-KA Accent Stripe - Satin Silver (CJPAB0) Center Rear Lamp RH/LH
7R3Z-6320000-KB Accent Stripe - Perform White (CJPAC0) Center Rear Lamp RH/LH
7R3Z-6320000-KC Accent Stripe - Vista Blue (CJPAY0) Center Rear Lamp RH/LH
7R3Z-6320000-KD Accent Stripe - Tungsten (CJPAZ0) Center Rear Lamp RH/LH
<20000 L Kit - Stripe Decal
7R3Z-6320000-LA Accent Stripe - Satin Silver (CJPAB0) RH/LH Lock cylinder housing
7R3Z-6320000-LB Accent Stripe - Perform White (CJPAC0) RH/LH Lock cylinder housing
7R3Z-6320000-LC Accent Stripe - Vista Blue (CJPAY0) RH/LH Lock cylinder housing
7R3Z-6320000-LD Accent Stripe - Tungsten (CJPAZ0) RH/LH Lock cylinder housing
<20000 M Kit - Stripe Decal
7R3Z-6320000-MA Accent Stripe - Satin Silver (CJPAB0) RH For License Plate
7R3Z-6320000-MB Accent Stripe - Perform White (CJPAC0) RH For License Plate
7R3Z-6320000-MC Accent Stripe - Vista Blue (CJPAY0) RH For License Plate
7R3Z-6320000-MD Accent Stripe - Tungsten (CJPAZ0) RH For License Plate
7R3Z-6320001-MA Accent Stripe - Satin Silver (CJPAB0) LHFor License Plate
7R3Z-6320001-MB Accent Stripe - Perform White (CJPAC0) LH For License Plate
7R3Z-6320001-MC Accent Stripe - Vista Blue (CJPAY0) LH For License Plate
7R3Z-6320001-MD Accent Stripe - Tungsten (CJPAZ0) LHFor License Plate
AND SOME EXTRAS
Rear Spoiler:
7R3Z-6344210-BA Spoiler, primed, paint-to-match
Front Bumper
7R3Z-17D957-APTM - Bumper Assy - Front
7R3Z-17K945-AA - Grill -lower
7R3Z-8200-A - Grille - Radiator
7R3Z-8A224-A - Emblem
7R3Z-17A385-CA - Bracket - License Plate
7R3Z-17752-A - Bracket - Bumper Mounting (RH)
7R3Z-17753-A - Bracket - Bumper Mounting (LH)
7R3Z-17626-AB - Lower valance panel
7R3Z-17C882-A - Isolator
7R3Z-8B455-A - Bracket
Wheels
7R3Z-1007-A - Shelby (VSF50P) 18 X 9.5 Alloy Wheel (D2UBS0)
2M5Z-1130-AA - Shelby (VSF50P) Center Hub - Version A (D5DBH0)
Front Brakes
7R3Z-1125-A - Front rotors - Shelby
7R3Z-2001-A - Front Pads Shelby
7R3Z-2B120-A - Front Caliper RF
7R3Z-2B121-A - Front Caliper LF
Coldy,
I thought you were going to suggest that all EXP had to do was go hang out at SAI as they would have plenty of stripes coming off all those cars for SS and 40th conversions. Surely they could find a match. OOPS, I forgot, we can't talk about that. Very professional response, I guess electric shock therapy works well these days. (this is all in fun, don't anyone get their panties in a wad)
Awesome info to save and keep!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! BillyRay
AND SOME EXTRAS
Rear Spoiler:
Front Bumper
Wheels
Front Brakes
Just an update the stripe is not quiet a color match because of some sap that got on the car and when the sap was removed it slightly faded the color of the stripe so a few more questions. It matchs close but you can still tell at certain angles.
I have to buy a complete kit now and was wondering as I see the price for buying each individual stripe will be 1399.93 total but the guy at the parts counter stated he could not find the complete kit Part number which I was told is about 200 dollars cheaper?
Also I heard this is parts MSRP pricing and I should be able to get 30-35% off so I just will order from an out of state dealer to avoid the sales tax in California.
So can I get a recommendation of a good parts dealer and is the 30% discout off MSRP true?
Thanks for all the replies.
PM TeamFord on the board and see what pricing they give. I think you should be able to get the stripes for around $1000. It really seems odd to me that the stripes would fade so quickly that you would have to change the entire set. If it is the stripes on the top of the car I would consider change just those two so they match when side by side. The are far enough away from the rest of the stripes that it would not be noticable if there is any difference. That would save you about $700.
A few of my friends said the same thing but the thing is I notice and it bothers me, I restore alot of old cars and its the getting the little details correct that drive me batty. I know sometimes 95% of people dont notice but I do.
It sounds strange to some people but everytime I look at the car it always bothers me. So I dont mind paying a little more I will send the person a PM.
When the car was buffed by the way it seamed to have faded the stripes a little but most people dont notice but I do.
