RevsUp Posted October 11, 2005 Report Share Posted October 11, 2005 According to Kzinti over at BlueOvalForums, my Legend Lime GT should be Built this Thursday (10/13/05). Although I've read the Owner's manual already and though it states there is no special procedures, other than varying the speed I drive during the 1K or so, there has to be some engineers out there that have a word or two about how to bring a new GT 4.6 Liter online. This will be a shared rig. I'll be the main driver and saying that I am a "Spirited" driver is... putting it midly. But saying I'll be abusing it would be going too far. One of the reasons I'm moving up from a Mazda Miata is so that I don't have to redline every gear to get around the guy next to me at the stoplight. Any real advice, not old urban sayings (Break it in fast, she'll be fast) are appreciated. Cheers, RevsUp Link to comment Share on other sites More sharing options...
JETSOLVER Posted October 11, 2005 Report Share Posted October 11, 2005 Change the oil often. Link to comment Share on other sites More sharing options...
Bullitt Posted November 6, 2005 Report Share Posted November 6, 2005 I would use the recommended oil, I'm guessing it's the usual 5W-20 synthetic blend, and change it and the filter every 3K miles up to 10K then switch to full synthetic 5W-30. At that point the engine should be broke in and the full synthetic will give maximum protection. Varying the speeds during the first 500 miles seems to make sense also. Hank Link to comment Share on other sites More sharing options...
Cobra1999 Posted December 17, 2005 Report Share Posted December 17, 2005 Famous last words........ "Drive it like you stole it!" Link to comment Share on other sites More sharing options...
ford4v429 Posted January 31, 2006 Report Share Posted January 31, 2006 I took it pretty easy on it the first 200 miles(not over 3.5k), was intending to baby it for 500, but just couldnt resist...I tried, but ....made it to 420 miles before I found it can scratch the tires in third and really bark em hitting second...almost 600 miles now, still havent redlined, but with the way she shifts at 5, dont think any reason to...at least not till I can get to a track this summer Man I love this car! Link to comment Share on other sites More sharing options...
SkyMaster 19 Posted May 23, 2006 Report Share Posted May 23, 2006 Any recommendations on why not to immediately go to Mobil 1? A lot of manufacturers already drop it into the engine at the factory...Vette's, Viper's, GTO's, BMW, Porsche, etc. Just got an 06 GT. Have always been a user of synthetic (99 Expy for example with 97K). Any thoughts? Link to comment Share on other sites More sharing options...
king Posted May 23, 2006 Report Share Posted May 23, 2006 This has all been discussed gentlemen, please see: GT500 break in period Options Link to comment Share on other sites More sharing options...
kaylan1521 Posted May 23, 2006 Report Share Posted May 23, 2006 Here's how I plan to break in my Shelby Near lane in this one. Lost by half a car length http://videos.streetfire.net/video/9198D02...814F09DD7F0.htm Or this way...far lane http://videos.streetfire.net/video/A5ECB25...6A6DAC30ACD.htm Link to comment Share on other sites More sharing options...
69boss429 Posted May 24, 2006 Report Share Posted May 24, 2006 The old school way,at 200 miles of carefull driving(not over 4500 to 5000 rpm) change your oil and filter.The next 500 miles work it a little harder,then change the oil and filter again.Now go 1000 miles ,drive it hard,but not stupid,and change your oil and filter.At this point you can go 4000 miles between changes and have a vehicle that will go for several hundred thousand miles.If they put it together to specs at the factory it should run very strong.When the time comes to rebuild,balance and blueprint it and you will be amazed at the difference. The old school way,at 200 miles of carefull driving(not over 4500 to 5000 rpm) change your oil and filter.The next 500 miles work it a little harder,then change the oil and filter again.Now go 1000 miles ,drive it hard,but not stupid,and change your oil and filter.At this point you can go 4000 miles between changes and have a vehicle that will go for several hundred thousand miles.If they put it together to specs at the factory it should run very strong.When the time comes to rebuild,balance and blueprint it and you will be amazed at the difference. The old school way,at 200 miles of carefull driving(not over 4500 to 5000 rpm) change your oil and filter.The next 500 miles work it a little harder,then change the oil and filter again.Now go 1000 miles ,drive it hard,but not stupid,and change your oil and filter.At this point you can go 4000 miles between changes and have a vehicle that will go for several hundred thousand miles.If they put it together to specs at the factory it should run very strong.When the time comes to rebuild,balance and blueprint it and you will be amazed at the difference. Link to comment Share on other sites More sharing options...
flattusmaximus78 Posted May 25, 2006 Report Share Posted May 25, 2006 FOr someone that likes to open up one it theres one thing you need to know. If your ganna hit the pedal hard turn the car on let it sit in idle... then just kind of cruize tull the engine is warmed up and at temp. Turn the ac of for better performance, it allways seems to help. And just hit it! Link to comment Share on other sites More sharing options...
creilly333 Posted January 5, 2008 Report Share Posted January 5, 2008 I just bought mine a week ago and it has only 300 miles on it. The car doesn't seem anywhere near as fast as I thought it would. I assume these engines get better as they loosen up, at least I hope so. I haven't been thrashing it, but it seems like it's holding back. Maybe I need to take it back to the dealership and have them check it out. Colin Link to comment Share on other sites More sharing options...
DDT Posted January 5, 2008 Report Share Posted January 5, 2008 I just bought mine a week ago and it has only 300 miles on it. The car doesn't seem anywhere near as fast as I thought it would. I assume these engines get better as they loosen up, at least I hope so. I haven't been thrashing it, but it seems like it's holding back. Maybe I need to take it back to the dealership and have them check it out. Colin What car did you buy? Link to comment Share on other sites More sharing options...
creilly333 Posted January 5, 2008 Report Share Posted January 5, 2008 08 4.6L Mustang GT with standard 3:31 gears. Colin Link to comment Share on other sites More sharing options...
07SHELBY GT Posted February 24, 2008 Report Share Posted February 24, 2008 08 4.6L Mustang GT with standard 3:31 gears. Colin The 3:31 equipped cars are a little lazy.But not to the point that you should be thinking WTF!Remember you are driving 281 cubic inches not 428,So they do lack a little down low especially with the 3:31 gears,Break it in and have some 4:10's installed and you will think they installed a supercharger! Link to comment Share on other sites More sharing options...
SGT/SC#0471 Posted March 21, 2008 Report Share Posted March 21, 2008 Best break in advice ever from Enzo Ferarri: "You want to go fast, break it in hard, you want it to last break it in easy". Interesting eh? Link to comment Share on other sites More sharing options...
RUFDRAFT Posted April 7, 2008 Report Share Posted April 7, 2008 08 4.6L Mustang GT with standard 3:31 gears. Colin Yes - 4:10's and a dyno-tune to increase throttle response! Link to comment Share on other sites More sharing options...
