BUICK468 Posted June 19, 2020 Report Share Posted June 19, 2020 Will a stock wheel and tire that came on the 2007 Shelby GT fit in the spare space in the trunk? My car has 500 miles on it and I decided to put new tires on it and saw only a compressor with a much expired patch kit from Ford and no scissor jack or lug wrench. Can someone tell me where the proper lifting points are for a scissor jack and if the car is put on a lift? Sorry for probably an old topic but I want to make sure I don't damage the car. Any feedback appreciated Quote Link to comment Share on other sites More sharing options...
Fat Boss Posted June 19, 2020 Report Share Posted June 19, 2020 Another concern is whether the spare will clear the brakes. Quote Link to comment Share on other sites More sharing options...
BUICK468 Posted June 19, 2020 Author Report Share Posted June 19, 2020 1 hour ago, Fat Boss said: Another concern is whether the spare will clear the brakes. I am wanting to use the factory size tire as a spare if it will fit in the trunk spare area Quote Link to comment Share on other sites More sharing options...
Carl Bishop Posted June 19, 2020 Report Share Posted June 19, 2020 28 minutes ago, BUICK468 said: I am wanting to use the factory size tire as a spare if it will fit in the trunk spare area The search button is your friend..... Quote Link to comment Share on other sites More sharing options...
mfield2a Posted June 20, 2020 Report Share Posted June 20, 2020 10 hours ago, 08SGT1234 said: The search button is your friend..... No. If you want a to carry a spare you have to get the donut. Quote Link to comment Share on other sites More sharing options...
arants Posted June 21, 2020 Report Share Posted June 21, 2020 It will fit in the well, but it will be too tall for the floor to stay completely flush. I've had a full sized original wheel in there since getting the car, but i dont carry stuff around in the trunk, so the uneven floor isnt a big deal. Quote Link to comment Share on other sites More sharing options...
BUICK468 Posted June 22, 2020 Author Report Share Posted June 22, 2020 On 6/20/2020 at 7:18 PM, arants said: It will fit in the well, but it will be too tall for the floor to stay completely flush. I've had a full sized original wheel in there since getting the car, but i dont carry stuff around in the trunk, so the uneven floor isnt a big deal. Thank you Quote Link to comment Share on other sites More sharing options...
RPM Posted January 24, 2022 Report Share Posted January 24, 2022 As far as jacking points go, I BOLTED on a Steeda jacking rail as to keep the pinch welds and subframes unmolested. For the rear the jack stands go in the differential, on the front I place the jack stands behind the wheels inboard where the, I think it would be called the k member, two big bolts that bolt the unit to the unibody. I also use hard rubber thingys on the jackstands. The jacking rail has a point midway to place your jack on so that the whole side of the car goes up. Quote Link to comment Share on other sites More sharing options...
99-9x Posted January 30, 2022 Report Share Posted January 30, 2022 I have a full size matching wheel/tire combo n our 2007 SGT.The inflated tire is higher than the floor.All we did was attach some risers to the Masonite floor.This worked well,you lose a little height in the trunk but the floor is stable and does not wobble.We used pieces of 2x4 fitted around the tire well. Quote Link to comment Share on other sites More sharing options...
