ShelbyBob Posted June 5, 2020 Report Share Posted June 5, 2020 Hello! I have a 68 GT 350 Hertz, where is the best place to source a power assist line, the ones I've put in keep blowing on me! Thanks Quote Link to comment Share on other sites More sharing options...
mhr1961 Posted June 13, 2020 Report Share Posted June 13, 2020 On 6/4/2020 at 10:01 PM, ShelbyBob said: Hello! I have a 68 GT 350 Hertz, where is the best place to source a power assist line, the ones I've put in keep blowing on me! Thanks Hi Bob, If possible go with Eaton hoses if they are still available. Its been a long while since I wrenched on a 68 so I don't know about current availability. You may also be able to take your current hoses to a local Aeroquip Store or Race Shop and have them make you a hose. They usually guarantee their work so if you blow a hose within the warranty they will replace it with no hassle. Below is a good article about routing your hose properly. Its on the Vintage Mustang Forums. Good Luck. Let us know how it turns out. https://www.vintage-mustang.com/threads/1968-power-steering-pressure-hose-problems.474852/ Quote Link to comment Share on other sites More sharing options...
Don Johnston Posted June 13, 2020 Report Share Posted June 13, 2020 You might check with the guys on the SAAC forum for what they recommend. Good luck. Is it a problem with the crimped connectors or the rubber hose itself?😎 Quote Link to comment Share on other sites More sharing options...
